Results 1 to 14 of 14
Thread: Tick clutch MC?
03-17-2017, 07:02 AM #1
- Jan 2008
- PITTSBURGH
- Blog Entries
- 2
SUNSET ORANGE- 2001 CAMARO SS
Tick clutch MC?
Anyone have the Tick adjustable MC in their Cars? Just wondering if this guys is worth the buy. I'm still having some spongy clutch pedal issues and occasional stick to the floor at higher RPM's. Replaced the fluid and bled the line when I replaced the new clutch master cylinder from autozone. I figured the one from autozone was probably crap. So trying to get any reviews on this bad boy.
Thanks.
03-17-2017, 07:57 AM #2
Yes, yes, yes......
Worth every cent.
Works great with the LS7 clutch I had and it's almost a requirement for the Monster stg 4 I have now.
I would also highly encourage getting the speed bleeder as well. Another thing worth it's weight in gold.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
03-17-2017, 11:14 AM #3
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
03-17-2017, 12:28 PM #4
- Jan 2008
- PITTSBURGH
- Blog Entries
- 2
Awesome. Thanks for the feedback gentlemen. I was hesistant on spending 300 bux on an MC, but seems like it has a great reputation. I'm hoping it takes care of my sticking pedal issue. If not, I guess out comes the tranny. Really trying to avoid this though. Glad to hear the tick MC will be a good purchase.
03-17-2017, 01:38 PM #5
Tick clutch MC?
The MC fixes the issue of shifting at high rpms & quick throws. The stock shifter has a small hole that for lack of a better explanation holds back the fluid.
The speed bleader makes servicing the clutch very easy. Almost a 1 man job if you run the hose a certain way.
03-17-2017, 04:14 PM #6
I still need one of these.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
03-21-2017, 10:55 PM #7
I want/need one too. I have had same issues with really fast aggressive shifts and a problem getting it into third,Its okay on a regular to lightly fast shift but if you try to speed shift as in really aggressive it has problems... Also is this something that's hard to install?....I barely remember past posts that had some degree of difficulty with the peddle or something like with the adjusting of it? No matter I WANT ONE !!!
03-22-2017, 04:39 AM #8
- Jan 2008
- PITTSBURGH
- Blog Entries
- 2
It's crazy bud. Exact issue I have. Easy shifting when I'm driving gingerly around town. Then the first time I go to hammer on it, third gear is so tough to get into and clutch pedal sticks. I've change the MC in my car a few years ago. It wasn't all that bad. A little tough to get to, but I did the install myself. The biggest pain for me was working under the dash. Darn seat in the way and not a lot of room to work. Not bad though. I had a hell of a time trying to bleed at the slave. My bro and I tried that method for a hour straight without any progress in the pedal. I read about using a mityvac at the clutch reservoir, and that worked wonders for me. Did not take long for me to get pressure in the pedal using that method. My issue was, I bought the auto zone brand MC and I'm assuming those are crap from what I've read. And, I ended up doing the drill mod when I put that one in. It seemed to help with the easy driving around town, but still a pain in the ass at WOT. My Tick is on the way. So, I'll let you know how that install was.
- - - Updated - - -
03-22-2017, 08:13 AM #9
Just warning you. It's a bitch to get in place. Have a 2nd person help. There is also a spring they refer to at where the loop connects to. It can also be difficult to deal with. Do not adjust the shaft to much until it is mounted. You can back off too much and then you're screwed The adjustment doesn't effect stiffness but is for pedal placement. It will feel more stiff then a stock mc. That is fine, you'll get use to it.
Also remember to reinstall the sensors if you disconnect for access ease. It effects cruise control.
03-23-2017, 04:40 AM #10
- Jan 2008
- PITTSBURGH
- Blog Entries
- 2
03-23-2017, 09:05 AM #11
Tick clutch MC?
did you get the speed bleeder too?
03-23-2017, 12:37 PM #12
- Jan 2008
- PITTSBURGH
- Blog Entries
- 2
I did not. Does the speed bleeder install on the slave? Do you have to pull tranny to install that? I usually bench bleed then use mity vac at resevoir.
03-23-2017, 05:08 PM #13
Tick clutch MC?
yes it connects to the slave. you just have to move the tranny back enough to tighten it on the slave.
03-25-2017, 01:45 PM #14
- Jan 2008
- PITTSBURGH
- Blog Entries
- 2
Well, Finally got it in today. It was definitely a job. Pain in the rear trying to get the old one out. The Tick surprisingly went in very nicely for me. And for some reason, the standoff or rod that screws onto the MC was jacked up. i could not get that thing to screw more than half way down. The lock nut moved freely up and down the rod on the MC. Darn standoff just gave me a rough time. Had to buy an all thread bolt from advanced to clean out the threads. Then it took a wow to bleed. I kept noticing air in the coming through the mity vac. I took it for a few test hits. So, no sticking clutch (which is great). However, 3rd gear is still a bit tricky to get in. And actually 4th. I'm kind of running out of time tonight to mess with it. I did adjust it twice. I'm thinking i gotta keep adjusting it. Whenever its at idle, it'll slip into 3rd pretty easily. All and all, I think it's a pretty nice gadget. Def feels more durable than the stock one.
Wanted: Tick master cyl, & aftermarket clutch
By BRANDON in forum Parts Wanted / TradeReplies: 13Last Post: 10-12-2013, 05:53 AM -
Tick-a-tick-a-tick-a-tick-a...Rear end when cornering
By bhunter0830 in forum Suspension and HandlingReplies: 8Last Post: 04-06-2012, 03:37 AM -
Tick MC installed, clutch is engaging at the top now.
By Kramsdell in forum Manual TransmissionReplies: 6Last Post: 11-22-2011, 08:29 AM -
tick m/c clutch installed already
By turyg ls1 in forum Camaro / SSReplies: 0Last Post: 07-20-2010, 04:26 PM -
wtb tick clutch master
By southpaw0314 in forum Parts Wanted / TradeReplies: 0Last Post: 01-17-2010, 12:07 PM
