Results 1 to 17 of 17
Thread: Making some changes...
02-19-2017, 09:44 AM #1
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I have a few questions hoping to get some help on...
I recently installed a UMI tourqe are relocation bracket on my TA and opened up a whole can of pinion angle problems mostly because I have a Non Adjustable TArm so I plan to replace it with a adjustable one this spring because after looking for a tail shaft housing and seeing the price of the housings for the F-body its dam near the price of the adjustable TA so I'm keeping the relocation bracket... Another thing I think is contributing to the pinion angle problems is the installation of the Strange S60 rear I feel lifted the back up some as it's just a bigger unit..
So I was considering dropping the rear springs 3/4 of a inch to LEVEL the car. I have non adjustable LAC's... Can I lower it that small amount and what I'm thinking bringing it back to more a stock ride height along with the adjustable TA to fine tune the pinion angle with out using adjustable LAC's????
Hope not to confusing
02-19-2017, 09:49 AM #2
Shouldn't present any issues with non-adjustable LCAs. My car is lowered with a 9" and my LCAs aren't adjustable. My wheels are perfectly centered in the wheel well.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
02-20-2017, 02:11 AM #3
Are you running the factory rubber cushion at the top of the rear springs?
02-26-2017, 07:57 AM #4
- Apr 2011
- Johnstown,PA
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
02-26-2017, 04:01 PM #5
Quick way to drop it a bit is to remove the pad and just run some heater hose over the top loop.
02-26-2017, 05:58 PM #6
- Apr 2011
- Johnstown,PA
I really don't know how much yet until I get it out and take some measurements and that will be something I consider...thanks
05-15-2017, 03:02 PM #7
- Apr 2011
- Johnstown,PA
Got my new UMI adjustable TA at Spring Carlisle pulled off the new old one and mocked up the new set up. Wanted to use the inside mounting holes but bracket wast hitting center section on my S60 so I went with the holes that lined up. After cycling the suspension I quickly realized first bump was certain under body damage. So off comes the bracket and modify it to fit the inside holes. Just wondering why UMI don't have the right bracket for different rear end's with out having to modify them? More to come soon
05-15-2017, 03:04 PM #8
- Apr 2011
- Johnstown,PA
Also removed the spring perch rubbers and installed the rubber hose.. Hasn't been on the ground yet but I can see there will be a difference just by the size of them
05-15-2017, 04:14 PM #9
try having a custom 8.8.....lol.
I had to also heavily modify my mounting bracket as well to get enough room so that it does rub or crush the floor pan bump under the drv side rear seat.
I also fliped my bolts that mount to the rear and torque arm to where the nuts are on top and secured them by using lock washer and red locktite. Makes it easier to install them.
For pinon angle you need to remove the drive shaft and try to get it on a drive on lift so you're at ride height and suspension is loaded. Next use angle finder on the output shaft of the transmission and on the pinon after you remove the drive shaft. Make adjustments on the torque arm to equal the measurement taken off the transmission output shaft but opposite. For example.
Transmission reads +2°
Pinon needs to read -2°
This will equal out the drive shaft and eliminate any binding on the u joints.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
05-16-2017, 05:01 PM #10
I ground the front corner off our torque arm.
05-18-2017, 05:44 PM #11
- Apr 2011
- Johnstown,PA
That maybe all it needs the bottom has no issues top is hitting.
Scott the guys at UMI told me to take my measurements from the driveshaft just in front of the rear and on the rear it self and add those two numbers together and adjust until I get -2 degrees. I bought a digital guage to help to be exact this time
05-19-2017, 06:00 AM #12
This video is about the best job of explaining how and why you set up driveshaft and pinon angles.
06-04-2017, 07:16 AM #13
- Apr 2011
- Johnstown,PA
Yeah I've seen that before very informative.. I'm happy to say I finally have completed my project I have so many things going on right now so not very much time. Anyhow set the angle as per UMI's instructions after a few test drives and a 100+ mph run yesterday no vibration and surprisingly enough very little cabin noise... I'm happy once again
Pinion angle was set at 3 degrees downward angle. Drive shaft was at 1.0 degree and rear was set at 2.0.... The digital guage was Awsome as adjustments were very fine 10th of a degree at a time... Worth every penny. Also per instructions M6 cars should be set 2-3 degreesLast edited by kingls1; 06-04-2017 at 07:24 AM.
06-08-2017, 05:24 AM #14
Do you mean -2 degrees?
06-11-2017, 07:50 AM #15
06-11-2017, 08:49 AM #16
I understand... knew it was a negative angle not positive so thought I'd mention it. You didn't have a negative sign in your post so thought I'd ask. Figured you had it correct.
06-14-2017, 12:41 PM #17
- Apr 2011
- Johnstown,PA
making a 98 run the way it should
By tims98ss in forum Camaro / SSReplies: 4Last Post: 03-31-2008, 05:56 PM -
How much HP am I making?
By 98 Z/28 in forum New Member IntroductionsReplies: 12Last Post: 02-10-2008, 04:13 AM -
Making Sure
By Arrison24 in forum Internal EngineReplies: 8Last Post: 05-02-2007, 07:57 PM -
Making a bad name!
By 56car in forum Almost Anything GoesReplies: 15Last Post: 10-17-2006, 10:32 AM -
making it better
By unus in forum Camaro / SSReplies: 10Last Post: 05-28-2006, 11:16 PM
