Thread: Less Boost=Less Horsepower?
01-10-2017, 09:37 AM #1
Ok guys,I know whatIi'm going to ask goes against eveything on this site but here goes. I have a C5 Z06 Corvette with a boosted LS1 with 800 HP at the crank in it. I autocross the car and am finding that this is a challenge to modulate the throttle without breaking the tires loose all too often. I am thinking about cutting the boost and a tune to get it down to maybe 600 HP-would this be as easy as a smaller pulley on the Vortech supercharger and a tune or would it need more work done to it? Here is a list of what is in the motor now:
Forged LS1 with Wiseco Pistons, Callie's rods and Arp bolts. Stock LS6 is 100% and comes with car.
A&A Vortec Si blower 3.4 pulley
Advance Inductions 226cc ported heads with BTR springs and rocker trunion upgrade.
Custom spec blower cam, LS7 lifters with hardened 7.35 pushrods.
Custom 4" blower inlet
Methanol Injection
Dewitt's cutdown radiator with spal fans
ARH 1 7/8" headers ceramic coated
Corsa exhaust
Mantic 9000 dual disk clutch with remote bleeder.
60lb injectors with in tank C6z06 fuel pump and kenne bell boost a pump
RPM Poly driveshaft couplers
RPM level 3 diff with 3.73 gears
ECS trans/diff brace
01-10-2017, 03:23 PM #2
Maybe I am misunderstanding you, but a smaller pulley on the supercharger will spin faster and create more boost, not less.
Welcome to the site!
01-10-2017, 04:48 PM #3
Sorry,I meant could a different size pulley be installed on the supercharger...
01-10-2017, 09:08 PM #4
I don't see why it couldn't, but that's a lot of HP/TQ you're looking to lose. Not sure how you determine how much boost you'd make with what pulley size on your exact setup.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
01-11-2017, 08:22 AM #5
Yes, you can change pulleys and technically make less power. Honest answer, you may be better off running a car that is setup for what you want to do versus compromising what you already have.
01-14-2017, 10:30 AM #6
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
A cam built for higher rpm power would help, as much of auto crossing is at light/part throttle.
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
01-14-2017, 06:42 PM #7
Or get fatter tires!!!!!!
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
01-14-2017, 09:00 PM #8
boost is a funny thing on the autocross course. truth is, from my experience, you'll need to find a setup that is going to net the flattest torque curve. I run with a few guys with turbo cars and they're downright wild when the boost comes on. granted, your supercharger is a different ballgame, but I believe the concept is the same. you don't need maximum power, but it needs to be managed in such a way that it's linear in it's delivery and not just a huge kick in the pants.
Worlds HIGHEST horsepower ZR1 18lbs boost
By LS2Tuner in forum Almost Anything GoesReplies: 6Last Post: 02-20-2009, 10:30 AM -
Boost Gauge vs Boost/Vacuum Gauge
By ls1camino in forum Forced InductionReplies: 6Last Post: 09-28-2008, 06:02 PM -
Horsepower Combos - Horsepower Rules
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-24-2007, 08:20 AM -
Boost Baby Boost
By DanWS6 in forum Rocky Mountain MembersReplies: 16Last Post: 04-03-2007, 11:37 AM -
Boost
By Got Boost? in forum Almost Anything GoesReplies: 61Last Post: 08-15-2006, 01:43 PM
