Thread: Build me a 3000 dollar mod list
12-04-2016, 04:39 PM #1
- Dec 2016
- russellville ar
red- 06 GTO
K guys build me a 3000 dollar starting mod list for a 06 M6 GTO that only has a cai! should be fun, i know how i like to go shopping for others. can go up to 3300 cause i usually get a 10% discount where I shop
12-04-2016, 07:25 PM #2
After spending a bunch of money on my Camaro, I've come to realize that the most worthwhile mods to me tend to be the ones that affect the "felt" response after driver input. So, I'd be focusing on brakes, chassis and suspension first. As for power, I might do a full exhaust as a simple bolt on.
Other than that, I'd go with slotted rotors, Hawk pads, stainless brake lines, sway bars and shocks.Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
12-05-2016, 06:25 AM #3
New bump stick (Cam - Tick Polluter stg 3) - $375
New Chrom-moly push rods - $130
LS7 Lifters - $100
Exhaust - $800
Beef up axle shafts - $??
Tune - $500+
Remaining - brakes. When you go fast need to stop faster...
12-05-2016, 09:27 AM #4
- Dec 2016
- russellville ar
red- 06 GTO
Forgot valve springs, necessary. Also I have to have a clutch/slave setup. one of them is going bad... 100k miles on the car so yea. MS4 cam seems like a better option, Similar to the polluter but no ptv issues
12-05-2016, 10:58 AM #5
MS4 is based on 15 yr ago, it has a steep rise and fall that is harsh on the valve springs. Many that have used it have said they have to check the valve springs every 25k miles.
The Polluter cam is perfect for a LS2 with stock or aftermarket heads.
I have it in my 403 stroker, with 6.125" rods and flat top pistons w/3cc relief cuts and have no PTV issues.
The LS2 uses the same length but with a 3.622 stroke crank so there shouldn't be any PTV with stock heads.
You should always check push rod length when you do cam and heads.Last edited by SMWS6TA; 12-05-2016 at 11:01 AM.
The day the Dollar died!!
By bluehawk2000 in forum Almost Anything GoesReplies: 0Last Post: 03-02-2011, 05:04 PM -
65 dollar lowers. get them while they last
By Modulistic in forum Gun's & AmmoReplies: 0Last Post: 03-08-2010, 10:17 PM -
ls1 dollar
By Nhra Firebird in forum Almost Anything GoesReplies: 57Last Post: 03-25-2009, 03:49 PM -
The Hundred Dollar Hot-Rod
By FORD RECOVERY EXPERT in forum Almost Anything GoesReplies: 55Last Post: 01-05-2009, 11:53 PM -
Can you Spare a DOLLAR?
By downunder in forum Political / Debate ForumReplies: 26Last Post: 02-16-2006, 01:16 PM
