Results 1 to 10 of 10
Thread: Radiator problem
10-02-2016, 03:55 AM #1
Radiator problem
After a good run at higher speeds I've noticed a little coolant leak. It's not very much and hasn't required me to refill yet, but it still concerns me. I haven't pinpointed the leak yet, but I'm guessing it's coming from the cap. The overflow tank is also suspiciously dry. I'm thinking that the radiator is all gunked up and preventing the system from dissipating excess pressure. Could it be anything more serious?
10-02-2016, 06:18 AM #2
- Apr 2010
- Alabama
The plastic in the radiator probably cracked. I've had it happen and I had to replace the whole radiator.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-04-2016, 11:51 AM #3
When's the last time it was serviced?
10-14-2016, 09:08 AM #4
I replaced my radiator about a year ago due to a complete rupture. After a little looking I realized the heater control valve was completely cracked and hemorrhaging coolant. I also learned that the part was discontinued lol. I looped the coolant hose back in on the radiator to bypass it completely. Seems to be fine so far, I'll just be without heat during the winter...
2005 Impulse Blue GTO
Kooks Longtube Headers (off-road mids) , SLP Loudmouth II Catback, Vararam OTRCAI, MSD Spark Wires, 238/242 .595, Trickflow 225cc Heads, SLP 25% UD Pulley, Breather, Elite Engineering Catch Can, 3200 TC,Hayden Trans Cooler, P&P TB, Dyno tune by Sunshine Performance
10-15-2016, 01:44 AM #5
They make a manual valve that can be installed on a heater hose. You may also be able to track another one down from a different model that will work as they are just a simple vacuum operated valve in most applications. Here is an AC Delco valve that Jegs offers: ACDelco 15-5812: HEATER VALVE | JEGS
10-15-2016, 11:10 AM #6
Much appreciated. Is running without the connection detrimental to the vehicle at all?
10-15-2016, 06:40 PM #7
As far as I know..NO. You will just be without heat like you said ,but the water will continue to flow and shouldn't be a problem.
10-16-2016, 01:39 AM #8
Not at all. Looping the heater hose is an old school trick for dealing with a leaky heater core.
10-16-2016, 11:54 AM #9
- Apr 2010
- Alabama
I've been doing it for a while since I deleted my HVAC. No issues.
10-27-2016, 05:30 PM #10
- Aug 2016
- Merrick,NY
- 2001 WS6
Help: Boiling sound at radiator, radiator cap blowin off
By lanprat in forum External EngineReplies: 7Last Post: 08-05-2012, 04:29 PM -
Griffin radiator install, stand up radiator install
By 02Sweet in forum External EngineReplies: 12Last Post: 06-03-2012, 05:00 PM -
Help: Radiator problem
By claytonr in forum Camaro / SSReplies: 2Last Post: 09-18-2008, 04:03 PM -
Problem!! Coolant Boils In Radiator!! HELP!!!
By L3THAL_Z28 in forum General HelpReplies: 32Last Post: 08-31-2008, 09:48 PM -
Project Shark Attack C3 Corvette Radiator Install - Radiator Fallout
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 04-03-2007, 09:20 AM
