Thread: LSx conversion questions
08-22-2016, 10:09 AM #1
- Aug 2016
- Redington Beach
- Looking for a Apache
Hey fellas.
So got out of the diesel game and looking to do a variant of the LS swap. Right now thinking either a LM7/LS3 depending on price into a Chevy Apache. But that could be some time off.
Some questions I have around different approaches/options -- basically around wiring/modules to link everythign together.
Appreciate some clarification or insight.
Approach 1 - Full EFI harnessed Conversion (donor harness worked or aftermarket)
LSx engine and full wiring harness (ECM/PCM) and DBW pedal and TCM. Painless aftermarket harness or Harness reworked and wired accordingly.
eg
painlessperformance.com/webcat/60524
or
painlessperformance.com/webcat/60221
or
ebay.com/itm/LS1-5-3L-6-0L-Engine-Wiring-Harness-and-PCM-Stand-Alone-Modification-/252448487636?hash=item3ac71a38d4:g:tMoAAOSwCypWmWS X&vxp=mtr
4l60E/4l65E engine with valve body work.
Essentially those are the main components required to make this work in a classic (accesories, fuel supply, gauges etc withstanding)
Between $300 and $900 in wiring/modules if you have the ECM/PCM and TCM etc from donor vehicle
Q1) Is there anything I am missing or not understanding here.
- - - Updated - - -
Approach 2 - Full EFI aftermarket conversion (aftermarket harness/ECU/PCM/TCM)
Same as above ........ but with regard to the harnesses you now run something like
fuelairspark.com/fas/gm-ls-ez-efi-2-0tm-self-tuning-engine-control-kithtml/ EFI and ignition control. approx $2k
or
superchevyperformance.com/19171130_LSX_Ignition_Controller_p/19171130.htm plus EZ EFI 2.0 EFI and ignition control) approx $2k
then
summitracing.com/parts/tci-302820 (transmission control) ~$600
So around $2500 additional to the engine/trans costs (then add accessories etc)
Q2) - Any advantage in going aftermarket here ??? Its pricier and then you have a bunch of compeonents working together. you would have support from that one company - but you know
08-22-2016, 10:11 AM #2
- Aug 2016
- Redington Beach
Approach 3 - Non EFI aftermarket conversion (carburated)
eldebrock EDL-91238 $540
1413-edelbrock-performer-series-eps-800-carb $427
summitracing tci-302820 (transmission control) ~$600
So around $1500 addtional (then add accessories etc) but now you are drive by cable.
Q3 ) What is the value in going this route over option 1 - unless your a carb fan ?
08-22-2016, 10:14 AM #3
- Aug 2016
- Redington Beach
Q5) What are the best "bang" for buck heads on a LSx 5.3 or 6.0 engine if you are planning ~400-450 hp. Some of the heads are pricing out at $1200 each.
Q6) At what point do you need aftermarket head studs Rule of thumb ? NA and FI.
Thanks guys
Have read and continue to read the books and forums - but these are some questions I have that aren't clearly answered.
08-22-2016, 01:44 PM #4
Each route you take has pros and cons as well as costs. What's you end goal? street, track, cruiser?
There are many ways to skin this...
For a 6.0L:
High output/flow look to LS3 heads. 6.0"s are the only GEN III/IV blocks that can use both cathedral (LS1/2 style) or rectangular (LS3 style) heads. Just need to match it with the intake, TB & injectors. LS3 will not work with 5.3 blocks. Ported & polish 243 heads can't go wrong if you stay cathedral, plus Trickflow has some bad ass heads for cathedral in both 5.3/5.7 & 6.0L
5.3L - heads depends on what you're building. For boost (FI) everyone I know that has done a budget build running boost is using 317 heads. With aftermarket comes a need for deep pockets.
Studs - always ARP. Make sure a machine shop verifies if it needs a line hone for the crank.
08-23-2016, 01:40 PM #5
- Aug 2016
- Redington Beach
End goal is really street/DD.
On the engine build though ....
Lets say you build a 5.3 ....... so ballpark $1k for good condition. Then add on $400 per head. Now a $200 cam, springs and retainers.
your at a ballpark $2k ........ versus buying a 5.7 true LS at say $2.5k.
So wondering where the savings is here unless you just run the 5.3 as is (meaning ~300HP versus closer 400 hp).
Seems like just better getting a LS1.
The 6.0 definitely looks interesting eg LQ9 at 345HP - so thinking with a cam and heads closer 400. But these are priced higher also.
Guess the best way to phrase the question with so many options as a base would be.........
1) most cost effective wiring/interoperability with engine
Rework of existing harnes/PCM and use DBW ...................... ballpark $500-$1200
2) Engine
Essentially bang for buck for HP on a street/DD.....circa 400hp. But able to grow.
08-23-2016, 02:46 PM #6
Differences between a LQ4 & 9 are just the pistons. 9's are flat top and 4's are dish. 9's have higher compression ratio over the 4's.
Newer 9's have the 243 or 799 heads (Both same casting, true 243's off a Z01 Vette have the Sodium filled valves, if off a truck they are regular valves like the 799's. You have to weight them to know for sure which valves you got.)
Best bang for the buck IMHO is a 6.0L. Wither you stay stock or bore it out you have plenty of potential over the 5.3 or 5.7 blocks. 6.0L hold more boost, can be bored out more, handle more N20, and are all around stronger then Aluminum.
I paid $250 for my 6.0L block. It had hydrolocked and only needed to be bore 0.005". I could have gone 0.030" over and made it a 408, just ran out of $$ and needed it up, so I'm happy for now with it being a 403ci.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
09-12-2016, 08:07 AM #7
- Aug 2016
- Redington Beach
Hey guys.
So some more questions ...... been researching on non engine stuff .... back to some engine stuff.
This is for a conversion into a 57 Apache.
How to determine correct offset/design of motor mount to ensure correct alignment of block and transmission in both the engine bay and driveline angle.
How to determine if I can fit a certain transmission in. Meaning would a 4L80E even fit in my truck ..... and how to work that out. There are some schematics floating around ...... but this partly depends on item #1 correct ?
A lot of the used engines for sale have obviously been wrecked. What tests would you do to get best idea engine is ok. Obviously compression and hearing it running (where possible) - but what else ?
VVT - do I want an engine with VVT - can it be turned off - do I want to turn it off on said build ?
Are there any engines I want to stay away from on this conversion ? For what reason - eg VVT .... *shrug*
09-15-2016, 10:52 AM #8
- Aug 2016
- Redington Beach
bump
Upgrading intake on a stock LS1, questions, questions.......
By mrbvlo in forum External EngineReplies: 6Last Post: 12-30-2011, 11:40 AM -
99 formula ws6 conversion questions
By LS1W in forum Firebird / WS6Replies: 18Last Post: 04-15-2007, 09:35 PM -
273 to 373... conversion
By 00maroz28 in forum DrivetrainReplies: 2Last Post: 03-29-2007, 03:08 PM -
FS:MAF Conversion Kit
By ldickson in forum Parts For Sale / TradeReplies: 2Last Post: 12-25-2005, 09:47 AM -
LT4 conversion questions
By r98vortect/a in forum LT1Replies: 12Last Post: 10-26-2005, 01:04 PM
