Results 21 to 40 of 60
  1. #21
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    I like those NGK Iridiums. I noticed an improvement in fuel economy after installing them (got about 40 more miles out of every tank).
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
  2. #22
    Member hardtrailz's Avatar
    Jul 2016
    SE IN
    Blue Green Chameleon
    2001 Trans Am Vert
    Seems to running really well with them. I got lucky and found the plugs on ebay that someone bought and never used for $32 shipped and the wires for $25 shipped.
    Took some extra washer to get full seal on AIR blockoff plates. Kind of annoying.
    I boxed up the ecm and it goes to post office today.
    2001 Trans Am Vert
  3. #23
    98 T/A w/ mods, 00 FBVert
    Quote Originally Posted by Naaman View Post
    For stock and daily driving I would use the TR-55 Iridiums. But once you go with a H/C/I you'll have to get different plugs depending on the build. I'm using TR6's, and when I was just mild bold on's I ran TR-5's.
  4. #24
    Jul 2016
    SE IN
    2001 Trans Am Vert
    I was going to do copper, but for the cost, I could not pass up the Iridiums.
  5. #25
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Mine also uses the TR6 right now. When I was stock, I had TR5s as well. It was the TR5s that I noticed the improved economy. Went from being empty after ~280 miles to ~320 miles. This was with every single tank of gas. Once I put in the TR5s, I never needed to fill up prior to 300 miles. On all the other plugs, it was always 280ish when I needed to fill. I'm currently running copper plugs, and I'm filling up between 265 and 280.
  6. #26
    You don't want to know what my MPG is with a 403ci, 8.8 rear with 4.10 gears....
    But it will move out....
    00 FB Vert - Stock
  7. #27
    Jul 2016
    SE IN
    2001 Trans Am Vert
    I was over 300 a tank stock
  8. #28
    I'm down to 200-230ish that is because of my heavy damn foot mostly. Mostly interstate driving on work days but on weekends lots of city/stop/go driving.
    I've yet to take it further than 80 miles at one time. I've been wanting to just fill up, point it on the interstate and see just how far it will go on without stopping.
    With 4.10 gears my rpm is about 2600-2800 in 6th gear at 80mph.
  9. #29
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Damn... I'm right around 2k at 80-85 (3.42s).
  10. #30
    Jul 2016
    SE IN
    2001 Trans Am Vert
    If I get past the highway commuting days i will be going with some lower gears, but for now the puny 2.73 get the mpg ok.
  11. #31
    Jul 2016
    SE IN
    2001 Trans Am Vert
    So the car has a few other things going on as of late. It got bumped and needs some paint work/repair and my buddy that happened to create the issue owns a GM dealership and sprung for a Smoothie-Q hood for it as well as making sure it is all fixed properly. Also going to have some tint on the windows and the AC and alignment checked out since it seems not to blow as cold and the tires feather lightly on the front. I also am up to 4 sets of wheels n tires for the thing. the Cup wheels in black chrome, the stock with snow tires, a set of 17s off a BMW and a set of the chrome 16 inch stock ABS wheels.
    Hood shipped Thursday so i should be taking car in shortly for them to fix it up. Been along 10 weeks waiting.
  12. #32
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Bummer about the paint/dent, but then, it seems like you'll be better off after all is said and done than beforehand, so can't complain too much there.
  13. #33
    Jul 2016
    SE IN
    2001 Trans Am Vert
    He almost cried when he told me he hit it. When we were young n dumb he was piloting my 96 Z as it hit a tree midair sideways and then he hits the car he took a loss on to get me into, so he has gone above and beyond to do this right. I tried to get him to give me the new Z06 he just bought in exchange, but will settle for all the lil stuff he is doing the car I have
  14. #34
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    Arizona
    383 Procharged & N20 Vert
    Oh man that sucks
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
  15. #35
    Jul 2016
    SE IN
    2001 Trans Am Vert
    Well I got her back.
    Smoothie Q Hood - vents painted black
    Dent fixed up.
    Paint for hood an repair blended then full clear on car.
    Tinted the windows.
    AC system refreshed w leak test and charge
    Alignment done cause the tires on 18s were chewed up due to it being out.
    So i got the stock 16s chrome wheels wrapped in some tires, but they are already back off and the snow tires on silver stockers are on.
    Stuck some synthetic oil and a wix oil filter in her Monday and tossed in a Spectre cleanable filter, but could not find the dremel to do the FRAM. Ordered an elctric cutout for the exhaust for her Christmas present.
    But anyway....
    Pics are what people like
    Attachment 26848
    Attachment 26849
    Attachment 26850
    Attachment 26851
    Attachment 26852
  16. #36
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Car looks great! Wish mine looked so nice right now...
  17. #37
    Looks beautiful!
  18. #38
    Jul 2016
    SE IN
    2001 Trans Am Vert
    Appreciate. Hoping to get the front plate insert painted and installed asap. For some reason it bugs me not to have it.
  19. #39
    Jul 2016
    SE IN
    2001 Trans Am Vert
    Well the wife popped out baby number 4 and I got a couple weeks off. Got bored in the garage and used a $2.50 can of gold plastidip I picked up to try out an idea. I had these BMW wheels and brand new tires listed for months and never even got an offer for what the tires cost, so I figured why not. If I hate it, I can paint them black and some high school kid will buy em. Plus i just get bored with wheels, hence having four sets for the car currently.
    They are 17x8 Rial Salerno with 245 45 17 Vogue Signature V
    Before:
    Attachment 26863
    After:
    Attachment 26865
    Attachment 26864
  20. #40
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    I think the color combo is quite nice. That gold probably wouldn't work with every color of car, but it really looks good on yours.
  1. Need Help with 2 in Drop
    By 99WS6MAN in forum Suspension and Handling
    Last Post: 03-09-2011, 06:38 PM
  2. Before & After - Drop it Low...
    By 35th-ANV-SS in forum Member's Rides
    Last Post: 07-21-2010, 03:40 AM
  3. best drop??
    By clg82 in forum Suspension and Handling
    Last Post: 07-29-2007, 09:25 PM
  4. Would u drop 7 on this car??
    By wonderboy in forum Almost Anything Goes
    Last Post: 09-19-2006, 06:48 PM
  5. Got my Job drop...
    By foshizl in forum Almost Anything Goes
    Last Post: 03-04-2006, 11:01 AM
