12-14-2015, 12:43 AM #1
KVR Drilled Rotors - Avoid or Remove Immediately
Worked for a while. ..BUT then developed dangerous radial cracks on rear face of rotors. Both on the front rotors. 2 radial cracks about 180 degrees apart. Cracked through the drilled holes across entire face of the rotors - both left and right wheels.
Do not buy these. They are extremely dangerous in my opinion. (I have 2 degrees in Aircraft Maintenance Engineering as well as FAA Airframe and PowerPoint Mechanic Ratings. )
If they fail and lose a chunk of the rotor, your wheel could lock up when applying brakes. The result at highway speed would be catastrophic, but spectacular.
If you have these on your car remove them ASAP. Inspect often until replaced and keep your life insurance paid up!
Regards,
Darden02 NBM TA - Mecham New Version Hood/Wing, Jet Hot/Hooker Headers, ProDyno exh, Chrome ROH ZS, Volant, Corvette LS1 MAF, Hotchkis LCAs, STB & Adj. PHR, BMR SFCs, Global West Traclink, SLP Bilstiens, Firehawk springs, B&M Ripper, Moser 12 bolt w/ 4.10s, Eaton Posi, LS1 Edit, Hurst line lock- more.
12-14-2015, 02:44 AM #2
Something you purchased on line or from a parts store?
12-14-2015, 03:28 AM #3
Online. Don't remember the exact source.
12-22-2015, 10:53 AM #4
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
I'm against drilled rotors on street cars for this reason. I've seen even name brand drilled rotors developing cracks. Slotted is the way to go for street
I like work. It fascinates me. I can sit and look at it for hours.
My Cardomain Site My Fquick site Custom Installs
12-22-2015, 07:27 PM #5
I'm of the opinion drilled rotors aren't really designed for street use either. However, proper design going into the rotor plays a huge factor. Some companies counter-sink and bevel the hole to reduce cracking. Proper metallurgy is critical too. Can't say I've ever heard of R1 Concept drilled rotors having an issue, but again, typically drilled are not recommended for street; only slotted or better yet, blanks.
12-23-2015, 03:20 AM #6
Slotted R1 Concepts on our car. Made a world of difference with Hawk HPS pads in how our car stops. I will never install drilled rotors on a street driven car.
Question: Slotted & Drilled Rotors.
By trnsman in forum General HelpReplies: 3Last Post: 06-01-2014, 09:03 AM -
Drilled and Slotted Rotors
By GULLETT17 in forum Suspension and HandlingReplies: 37Last Post: 03-05-2008, 11:51 AM -
LS1 drilled and slotted rotors
By rll2 in forum Parts Wanted / TradeReplies: 6Last Post: 01-12-2008, 07:45 AM -
Best Slotted and Drilled Rotors
By {FzS}BlacKMagicK in forum General HelpReplies: 55Last Post: 03-21-2007, 09:59 AM -
Ebay drilled rotors
By 98eles1 in forum General HelpReplies: 8Last Post: 03-23-2006, 01:57 PM
