Results 21 to 26 of 26
Thread: 98' Camaro v6 to 5.3L swap
08-03-2015, 08:04 AM #21
Rear Axles discussions are like who makes the best cam/heads/LT headers....
All are in agreement that the stock 10 bolt is a major POS.
12bolt's seem to be the popular recommendation for Auto's
9" for Manuals
8.8's and Dana 60's are somewhat new and work well for both auto and manual cars. I don't know much about Dana60's sorry.
Some pro's and cons of 8.8" vs 9"
9" are strong as hell. Takes one hell of beating, the 3rd member is what makes them highly sought after for track use. 30 mins you can have a totally different gear set, break a ring gear or pinon, pop in your spare. Huge support for aftermarket parts.
Cons - heavy, requires a specific torque arm, drive shaft, average drive train loss is around 20-23% (What I mean is engine making 500hp at the flywheel, you're making about 385ish hp at the wheels).
8.8's
Pros - lighter then 9", strong as hell but 9" is more so, Average drive train loss is 15-18%. Price cheaper than 9", Huge aftermarket parts support. A WAVETRAC diff is now offer for 31 spline axles. You can use your f body style torque arm and drive shaft (after a new u joint is installed to mate to 8.8 pinon piece.
Con's - sorta new to being availability, Most 8.8's are like mine, custom fab. I only know of one place that is now offering them as a production piece (Hawks3rdGen).
I'll leave the 12bolt and Dana60 guys explain them.
For a car that is going to see a few passes at a track I would not recommend the 9". That would be serious over kill.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
08-16-2015, 04:54 AM #22
- Jul 2015
- Minnesota
How can I message you directly?
08-16-2015, 05:27 AM #23
me?
08-16-2015, 06:25 AM #24
- Jul 2015
- Minnesota
Yes or Transam if any of you are willing to give me further advice into this engine swap adventure Haha. I decided to say hell with it and just go big and do the 6.0 (: Figured you guys would be good advisors if you're willing. Only other thing that has changed is that I may be doing this in a 3rd gen instead, I'm undecided on which one yet since it'll be hard letting go of this car. So if either of you are interested, it would be amazing if I could talk to you guys about any questions I may have
08-16-2015, 06:29 AM #25
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
08-16-2015, 03:21 PM #26
check your inbox
v6 camaro swap to ls1 help
By dag27 in forum General HelpReplies: 7Last Post: 04-18-2012, 04:08 AM -
doing a LS1 swap in a 94 camaro
By 94 ls1 Z28 in forum Parts Wanted / TradeReplies: 1Last Post: 11-03-2010, 06:43 PM -
Question: 69 camaro ls1/6speed swap (out of my 2000 camaro)
By colburn22 in forum Classic MuscleReplies: 0Last Post: 09-18-2010, 01:37 PM -
Just got done with a ls1 to ls6 camaro swap
By sbss01 in forum Camaro / SSReplies: 1Last Post: 08-11-2009, 06:23 AM -
67 Camaro LS1/T56 swap almost done....
By 67rsss in forum New Member IntroductionsReplies: 1Last Post: 06-18-2007, 08:27 AM
