Results 1 to 18 of 18
    Omaha, NE
    2000 Z28 Camaro
    1999 Pontiac Grand Prix Misfire under load
    I can't figure out what's causing a random misfire under load in my GP.
    It's the worst when going up a hill, I have to make it shift out of OD and hit about 3k rpms so it doesn't misfire. So any time it hits OD and the load is high, it'll miss HARD. Often times it'll miss with the A/C on at a light, or even idling as well.
    Things I've changed/tried:
    -TB cleaned
    -MAF cleaned
    -Air filter changed
    -Fuel filter changed
    -EGR valve cleaned, then replaced with a different used one
    -Plugs/wires changed (off-brand) might try ACDelco
    -all 3 ignition coils, changed, new
    Perhaps a faulty ignition control module?
    Fuel? I know nothing about fuel systems, so i'd need a pretty lengthy explanation on what to check.
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by allbaugh_04 View Post
    -TB cleaned
    -MAF cleaned
    -Air filter changed
    I presume this is a 3.8 v6 code K engine? I remember selling alot of intake gaskets for those when I worked for a Pontiac parts dept. I would check for a vacuum leak at the manifold, but I dont think it will fix you problem all together. Have you ruled out the IAC motor or the TPS? If they are faulty, that could throw off the ECM.
    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Common issues with a 97-03 grand prix are the
    Lower Intake Manifold Gaskets
    The Upper Intake if it is not supercharged can warp and leak coolant.
    Front Wheel Bearings
    Ignition Switch
    Do you have a service engine light? Did you clean the IAC valve?
    Check for any vacuum leaks
    Have you ever done a trans filter and fluid change?
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    I would check fuel pressure - not sure what the spec is for your car though. Absent a fueling issue, I have to agree with what has already been posted. Are you simply getting a misfire code through the check engine light, or is something else popping up too?
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    I had a 99 that was doing the same thing and I couldn't figure it out after changing the same stuff. So I sent it down the road. Really liked it but it was time to go.
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
    Omaha, NE
    2000 Z28 Camaro
    Quote Originally Posted by Whamhammer View Post
    Yes K engine. I don't hear a vacuum leak, but I was looking online and u just use carb cleaner and spray around the intake? Is that about the only way you can check? I have no codes for the IAC or TPS, no I haven't ruled them out then.
    Quote Originally Posted by The Guz View Post
    Ignition Switch
    I just had a few codes for the map sensor come up, so I replaced that with a used one from the dump. I'll take it for a drive today; been busy.
    I have not cleaned the IAC valve, I will try that if it persists.
    But I did have a P1811 code for Maximum Adaptive & Long Term Shift. I replaced the trans fluid and filter probably 40-45k ago. I would have to check my maintenance log is in the car, but I'm not sure if that needs done again, what you think?
    How do I go about checking fuel pressure, I've never dealt with a fuel system on a car.
    Quote Originally Posted by kingls1 View Post
    I feel the exact same way, it's been pretty frustrating. I really like it as my point A to B car though. :/
    You can rent a fuel pressure gauge from most parts stores... or just buy one. Find the rail that supplies fuel to the engine and there should be a plastic cap screwed onto a schrader valve (pretty much looks like a metal valve stem on a wheel). Remove the cap, attach the gauge and energize the ignition to see what you have for fuel pressure. Then start the engine and see what happens - once the engine is warmed up a bit rev on it to see if it holds pressure or if you see a significant drop. You will have to find the spec for fuel pressure as I am not certain what it should be for your car.
    Omaha, NE
    2000 Z28 Camaro
    Perfect, thanks a lot, I will give it a shot.
    You can check for an intake leak with either WD-40 or even a propane torch (not lit, of course ) With the engine idling spray around the base of the intake (or run the torch around it) and if the engine suddenly idles up on its own then you found your leak.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    I change my trans fluid every 30-50K miles. You may want to install a trans go shift kit the next time you do it.
    I did find this
    Harsh Shift, P1811
    Omaha, NE
    2000 Z28 Camaro
    Ok i changed that map sensor, drove nice for a day.
    Tested ignition control module since that is free. Its good, they didn't have fuel pressure tester, going to try that tomorrow then check prices for iac and tps sensors.
    Could this be injectors or a plugged cat? O2 sensor?
    Omaha, NE
    2000 Z28 Camaro
    I posted this^ when I was at advance auto. I cleaned the contacts of the ICM and the grounding points when I got home and it hasn't misfired since. I won't hold my breath though, as soon as I unhook something and hook it back up, the misfire usually comes back a few days later, but we shall see if it persists or not.
    98 T/A w/ mods, 00 FBVert
    Is this a 3800 engine?
    My 96FB had an issue that turned out to be the plate the coil packs sat on that was similar in what your having problems. It got so bad it blew plug wires apart.
    Omaha, NE
    2000 Z28 Camaro
    Yes, the 3.8 series II. And yes, that plate is what I cleaned up. It's been 3 days and it's misfiring, but it's hardly even noticeable. Most people would never notice it. I might take it apart and clean it some more. I hope that's the issue, because I am so sick of this issue
    I know there was a notice put out that said those plates needed replaced every 70,000 miles. I'm not saying that's the issue just that it seems to be the same problems I had. It took me 6 months chasing that bitch down. Then I came across the notice and replaced it, night and day difference.
    Have you pulled the plugs? You might have an injector going bad.
    Have you check that fuel pressure yet?
    May be time for a compression test. This will help rule out any gasket leaks.
    Omaha, NE
    2000 Z28 Camaro
    I haven't ruled out an injector for sure. Spark plugs have been changed twice since this started. I have not had time to check fuel pressure, hopefully I find time this weekend, the fuel pressure tester has been hard to track down without buying one.
    If there was a decent wrecked grand prix at the dump, I would go pull one of those plates off, but they are all over 200k miles. I'll probably have to buy a new one.
    If you do get a plate from another car at the very lease you can see if it fixes it temporary till you can. Those damn things are expensive, at lease they were back in 2002.
    I just look they've come way down ($123 on rock auto DELPHI DS1004)
    I ask about the plugs because looking at the tips will tell you a lot.
    Wet & smells like gas - you have an injector issue
    Black and oil - head gasket or rings
    Smells like coolant - head gasket
    White - lean on fuel
    Compression test will also help narrow down. They should be with 10% of each other.
    Fuel Pressure will let us know if it's charging the system and keeping it at constant pressure. One more thing to add to what Jeff said to test the fuel pressure. Turn key to on, no start, pressure should come up, it should hold and not bleed down, if it does then the pickup tube for the pump to the lines has a crack in it. It happens with age.
    Omaha, NE
    2000 Z28 Camaro
    Thanks for all the help guys. Thanks Scott.
    I took some sandpaper after that plate a month ago. I haven't had it misfire since. Weird issue, but I think it's over now
  1. 1962 Pontiac Grand Prix - Pontiac Joeâ
    Last Post: 01-20-2014, 10:50 PM
  2. Replies: 0
    Last Post: 03-16-2011, 09:30 AM
  3. Replies: 0
    Last Post: 09-29-2007, 06:50 AM
  4. 1973-1977 Pontiac Grand Prix - A Grand History
    Last Post: 08-15-2007, 12:50 PM
