Thread: Looking at going turbo
06-11-2015, 07:08 PM #1
I'm thinking about doing a huron speed turbo kit. truck manifolds etc. Wondering if anyone has the kit. Likes dislikes... etc.
Also at what point do you forge everything in the motor. looking at just doing a low boost set-up. Obviously dont want motor issues. Just trying to figure out what I can get away with safely.
06-12-2015, 08:48 AM #2
Once you get much past 500 rwhp, that's when I'd start going inside the engine and forge it. Low boost? Just keep it under 9 psi(intercooled) or so....but you could probably boost a little more with a methanol injection system.
06-12-2015, 12:38 PM #3
Iron blocks can hold more boost over aluminum. 7-9lbs is what I see with the aluminum blocks. We have a local guy runing a turbo on a 5.3 putting some serious numbers on stock bottom end, 317 heads and truck manifolds. Just don't skimp out on the oil feed/return lines for the turbo. He had one blow on a hard pull and toasted the engine.
00 FB Vert - Stock
06-17-2015, 07:37 AM #4
01-08-2024, 08:07 AM #5
- Jul 2009
- california
blue- 1998 camaro z28
I have a holley 550-934t for sale $1350 shipped is new in box never used
turbo ls 240sx vs turbo mustang + video
By Sleeper101 in forum Kill StoriesReplies: 30Last Post: 07-26-2011, 09:44 AM -
Wanted: Trade my HUGE turbo for your smaller turbo
By Iknowthefuture in forum Parts Wanted / TradeReplies: 0Last Post: 08-30-2010, 05:47 PM -
Pontiac Firebird Turbo Installation - Subterranean Turbo System
By Ed Blown Vert in forum GTOReplies: 0Last Post: 09-29-2007, 06:50 AM -
By Ed Blown Vert in forum Firebird / WS6Replies: 1Last Post: 09-12-2007, 06:16 PM -
camaro turbo vs 3000gt turbo
By GONZO SS in forum Multimedia SectionReplies: 6Last Post: 01-01-2007, 06:58 PM
