Results 41 to 50 of 50
02-06-2018, 07:23 AM #41
Its old post, but after this long....was the 9 inch the right width for the 275 35 18? I got a set of those tires in the garage and was going to squeeze them on my 18x85, but then was thinking to go 18x9 or 9.5 if I can find some I like. I don't think I would want anything wider really.
2001 Trans Am Vert
02-08-2018, 03:31 AM #42
The tires work well on the wheels. I was just thinking about this the other day: at my current power level (360 wheel), I sometimes have trouble with traction in 1st gear at WOT, even with a rolling start: it's not that the tires screech and lay rubber, but when the road is not perfectly flat/smooth, it's like they just skip a little bit (the engine continues to rev, but there are split second lags in the surge of G forces... this, of course, is as measured by the seat of my pants). Generally speaking, accelerating away from the on-ramp meter, the car pulls strong all the way to redline. One the street, if there are little pebbles or cracks in the road, or if it is remotely bumpy or whatever, I think I can feel little "slips" that last some very small fraction of a second.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
02-08-2018, 04:17 AM #43
You think a wider wheel with creating a flatter profile of the tread on tires would help that lateral strength? I see mostly that the skinny wheel will flex the tire edges and compromise sidewalls allowing them to roll over. You think that could be happening?
02-08-2018, 02:20 PM #44
I don't know... perhaps so. It was a long and arduous endeavor to figure out what wheel/tire combo to get. I would have liked a 9.5", but after looking into it, I found that the wheels I wanted (light weight, 18") did not come available with the right bolt pattern for my car.
02-08-2018, 02:26 PM #45
I am thinking I will try the 8.5 with the 275 35 18 I have and see how it works
02-09-2018, 03:33 AM #46
02-09-2018, 07:27 AM #47
02-10-2018, 07:49 AM #48
So... what you're saying is that it takes a torque arm to fix that....?
02-10-2018, 03:58 PM #49
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
02-11-2018, 06:52 AM #50
Well, according to my reading... LCAs and relocation brackets, PHB, and torque arm are the means to address it.
I have LCAs (poly/roto combo), adjustable PHB, Koni shocks... seems like either the relocation brackets or the torque arm... if what I'm getting is indeed wheel hop...?
Question: Tire width options
By dethinboots in forum Wheels and TiresReplies: 6Last Post: 01-06-2013, 04:16 PM -
max wheel width and tire width for C5?
By MachWon in forum CorvetteReplies: 18Last Post: 04-17-2010, 03:38 PM -
Question: Tire Width Concerns
By Cobra Killer in forum Wheels and TiresReplies: 2Last Post: 02-03-2010, 12:03 PM -
max tire width in front for DD
By swisscheese in forum Wheels and TiresReplies: 17Last Post: 11-12-2008, 11:07 AM -
tire width and height
By Chevyfan99 in forum Wheels and TiresReplies: 3Last Post: 07-28-2008, 06:59 PM
