Thread: smog pump
05-26-2014, 08:31 PM #1
smog pump
What all do have too do for the smog pump removal on 1995 trans am
05-26-2014, 10:45 PM #2
Take the pump off, plug all the holes where it unplugged from, and have the code programmed out.
05-27-2014, 08:30 AM #3
smog pump
so u do need to get it programmed out. I was told no programmed was needed for the 95 lt1
05-27-2014, 09:30 AM #4
It will still pop a CEL code because it is part of the ECM's program. You can still drive it.
05-27-2014, 10:37 AM #5
smog pump
ok I'm just gonna leave there
05-27-2014, 10:49 AM #6
Are you talking about the air pump or the egr?
Air pump you can just pull it, plug the side hole in the air lid and remove the fuse, for the egr you need to block off the exhaust tubes and intake. Not hard to do and takes less then an hour.
05-28-2014, 05:53 AM #7
05-28-2014, 07:36 AM #8
Ok then yeah pull the system and plug the hole on the air lid. It shouldn't trip the cel, the egr does though.
05-28-2014, 10:43 AM #9this post is meant as a joke and in no way should it be interpreted as a serious or meaningful reply. The author of this post cannot be held liable for any damages, both emotional and physical, that may be incurred from the reading of this post. By acknowledging this disclaimer you hereby release the author from any and all liability
1999 trans am smog pump?
By FutureWS6 in forum General HelpReplies: 8Last Post: 03-31-2010, 03:58 PM -
Smog Pump location?
By Patsy57 in forum External EngineReplies: 5Last Post: 06-27-2009, 02:37 AM -
Power Steering pump leak?! new pump or seal kit?
By JehalinTA in forum General HelpReplies: 2Last Post: 03-18-2008, 10:05 PM -
looking for a 00+ Smog pump
By FORMULA7 in forum Cowhands, Local Parts and Fish BaitReplies: 2Last Post: 09-22-2006, 10:48 PM -
What items can be taken off (ex. smog pump)
By notchback in forum External EngineReplies: 2Last Post: 11-30-2005, 05:28 PM
