Page 4 of 4 FirstFirst 1234
Results 61 to 64 of 64
  1. #61
    Member Decadence75's Avatar
    Aug 2013
    Missississipi
    Bright Red
    2000 Trans Am
    Here's another option for turbos if interested.
    Turbo Kits
    I think because of this thread was the reason I went with a 403 build.
    Thanks for the link. The TT one I posted caught my eye because it is supposed to fit as is into the car keeping all amenities. Though I am still not sure if I want to deal with FI on a car that is a semi daily. The 408 option still seems like it might be the best path if I can ever get the cash together for it.
    I'm glad that I could have contributed in some way to you building an awesome car.
  2. #62
    98 T/A w/ mods, 00 FBVert
    403 build - Advice and Opinions
    It took a year but I piece milled mine. I'd buy parts I needed once a month. The biggest 2 purchases were the Fast intake & the K1 Stroker Crank.
    00 FB Vert - Stock
  3. #63
    Aug 2013
    Missississipi
    Bright Red
    2000 Trans Am
    I know it has been forever since I updated this thread. But last night I was given the opportunity to buy a 6.2L block and took it. So hopefully that will pan out and I can have decent numbers N/A.
  4. #64
    Nov 2022
    amesterdam
    I have replaced every bolt I can with ARP so far and the day my motor gets cracked open ARP will be the only bolt used...cost of new bolts are far cheaper than rods or new block! Jmo
  1. engine build opinions ?
    By 2NDSLPSS in forum Internal Engine
    Last Post: 01-01-2012, 11:04 AM
  2. Need some advice/opinions
    By Red99TA in forum General Help
    Last Post: 09-18-2009, 05:57 PM
  3. LSX 454 Build Sheet and Opinions
    By NeeD4SpeeD in forum Internal Engine
    Last Post: 09-09-2009, 02:14 PM
  4. 408 build any opinions
    By jmdgto in forum Internal Engine
    Last Post: 06-16-2009, 07:06 AM
  5. need opinions on build
    Last Post: 05-19-2009, 09:22 AM
