Results 21 to 27 of 27
Thread: car emergency, please help!!!
04-30-2006, 05:05 PM #21
-The shop had fixed the blinkers, that was the only problem at that time. So they prolly wont take it back as something they didnt fix right. The blinkers do work just that 1 inside is still lighting up all weird, outside they are fine.
-Yes ive checked the pump relay, its fine, i tryed switching it with the AIR 1 or something like that...the 1 right next to it.
-Yes i have a test light, that and a voltage meter. Thats how i know im not getting any power to the fuel pump.
05-07-2006, 07:59 AM #22
!!!!!!!!!!!!!!!!!!update!!!!!!!!!!!!!!!!!!
Heres an update...i still have 5 days before the car goes to the shop so i figured id try out some more looking and with the help of my friends dad. Took the headunit out to look at wires and came up with some intresting things. Lots of wires disconnected and other things. I took pics and wrote down what each wire is. It seems like everything for my alarm is unhooked, i know i have 1 becuase i have the sensor thing in the back by the spare tire. Everything on my remote entry works (truck release, door unlock and lock, panic button) Maybe someone can see something wrong here which may have led to my short or w/e the hell my problem is. Thanks guys.
-brown-alarm output.....b
-black/yellow-mute.....by
-orange/white-door lock.....ow
-red/white-alarm sensor.....rw
-yellow/white-door switch.....yw
-blue/white-system remote control.....bluew
-red spliced with black (you cant see the black wire in the pics but its connected to the red with the blue splice thing the black wire is also thivker then all the others-the red is the acc.....rb
-red and black connector-i have no idea what this is but its totally unhooked and i couldent find anything that it could have plugged into. Also, 1 of the wires coming out of it is totally bare, like just wire, no rubber covering.....rbc
05-07-2006, 09:42 AM #23
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
I thought brown was mute
05-07-2006, 09:53 AM #24Originally Posted by oneBADDz
05-09-2006, 03:12 AM #25
- Apr 2006
- Apple Valley MN
Red- 2001 Camaro ss
sorry to hear of all the problem, I have a 99 tahoe, that one day just started making random noises like you had left the turn signal on. I checked all all my lights and everything worked fine, and it seems to make the noise more when it's colder out. I talked to the dealer about it <and a friend who is a service advisor> and they both said it's a multifunction switch. I guess it controls all you'r lights, horn, and it is mounted in the steering wheel colum. for my truck after they diagnosed, and depending on vin # was going to be around $800 to $900, so I have just put up with the noise when it does it but they said it will go, and could loose all you'r lights. just and idea, mine has alway's started and ran fine. that might also control some other things, why you'r car won't start
05-09-2006, 09:03 AM #26
05-09-2006, 10:35 AM #27Originally Posted by Danger731
Go Bag Checklist for an Emergency
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 09-05-2011, 12:30 AM -
emergency brake issues
By 2NDSLPSS in forum General HelpReplies: 3Last Post: 06-15-2010, 08:33 PM -
Emergency brake?????
By SandmanWs7 in forum Manual TransmissionReplies: 7Last Post: 03-16-2010, 07:12 PM -
clutch emergency.... help!
By The_Wretched in forum Manual TransmissionReplies: 2Last Post: 03-06-2008, 03:30 PM
