Results 21 to 40 of 78
Thread: Another Build Thread
08-28-2012, 04:06 PM #21
Ill bump this for ya. A4-tranny cooler and stall convertor. Stall only if you won't spend lots of time dragging it, cooler if you can afford it irregardless. You can do this yourself.
M6- Tick MC, upgrade clutch, and rebuild. Rebuild alone little under 2k. There has to be someone in your area that can do the rebuild for ya, and save shipping costs. That's a couple hundred right there.
08-29-2012, 09:43 AM #22
It may have a cooler already. When it went out on me about 4 years ago, the guys that rebuilt it said it had a lot of upgrades. Didnt tell me exactly what though and calling them to find out isnt an option. Businesses in Hawaii tend to not give a damn about things after they are out the door.
Suspension: Lower control arms (Spohn), Drive shaft safety loop, Torque arm (Edlebrock), Strut tower brace, Panhard Bar (BMR)
Under the Hood: Smooth bellows, Lid, Catch can, LT Headers, ORY, AIR/EGR delete, Poly engine/transmission mounts,
Exterior: Painted brake calipers (Red), Halo “Spyder” Headlights w/matching parking/turn signals (Black)
08-29-2012, 04:14 PM #23
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
3500 or bigger stall, you will regret that 3200.
08-29-2012, 04:20 PM #24
08-29-2012, 04:31 PM #25
- May 2010
- Wilkes-Barre, PA
A bigger stall will keep you in your power band of that cam, I'm not sure if 3200 is enough. I have a Yank 3600 with a V.2 and I wish i went with a bigger stall. around town the car drives just like it did when it was stock (sorta).
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
08-29-2012, 04:36 PM #26
a tranny cooler will be easy to spot.....they're usually put in front of the radiator and look like another smaller radiator except they tie into your tranny lines. Your tranny lines come out pretty much where your crank pulley is. You will definitely want to make sure you have one before doing a stall. As far as the stall I agree......3500-3600 would be what I would get. Actually....it is what I got.....a 3500.
08-29-2012, 04:52 PM #27
Thanks guys. You two agree with the LS6 intake and P/P stock TB?
08-29-2012, 04:54 PM #28
- May 2010
- Wilkes-Barre, PA
I do! I made some good power with a LS6 intake before I got a FAST 92. The LS6 is 100 times better than the LS1 intake
08-29-2012, 06:11 PM #29
My only fear (if you can call it that) is that I will get it, get use to the added power up to that point and want more. From what Keith said, the FAST would only add about 15-20HP. To me, thats not worth 1300 extra dollars.
08-29-2012, 06:13 PM #30
- May 2010
- Wilkes-Barre, PA
I gained about 30rwhp with a fast 92 and a electric water pump.
08-29-2012, 06:14 PM #31
Im probably going to do the underdrive pulley as well.
08-29-2012, 06:17 PM #32
I just had to replace my water pump too. Guess I could hold onto that one IF I went with an electric. As of this point, I am leaning towards the LS6 simply because of how much money it saves me.
09-02-2012, 04:41 AM #33
Rear end question...rule of thumb is 12 bolt on A4 correct? Gears 3.73? If I go that route, what are the other specs on a rear end that I need to take into consideration? Such as spline and differential? I have NO CLUE what to look for in this category.
09-05-2012, 11:09 AM #34
Opinions on S-60 vs. a 12 bolt?
09-05-2012, 01:29 PM #35
09-05-2012, 01:33 PM #36
A guy at Strange said S-60 too
09-05-2012, 03:18 PM #37
Weld in or bolt in SFC's?
09-05-2012, 04:27 PM #38
Bolt in. What happens if you want to change them? Or need to? Who knows, you hit a speed bump and bend one. Or you need to remove them to access some thing?
09-05-2012, 04:36 PM #39
09-05-2012, 04:58 PM #40
My 98 Z28 build thread...
By ChevyZ76 in forum Member's RidesReplies: 15Last Post: 08-02-2014, 01:24 PM -
LQ4 Turbo Build Thread
By My00Z28 in forum Forced InductionReplies: 89Last Post: 08-28-2013, 12:41 PM -
Build Thread 2.0
By tep98ws6 in forum Internal EngineReplies: 23Last Post: 08-07-2013, 06:56 AM -
Members build thread
By 10spokess in forum Request and FeedbackReplies: 14Last Post: 07-21-2011, 07:21 AM -
My Build Thread!
By tep98ws6 in forum Internal EngineReplies: 236Last Post: 07-17-2010, 07:56 AM
