Thread: Alternator Replacement
06-19-2012, 06:55 PM #1
I've swapped my alternator 3 times during the life of my car. I think that I cuss more each time that I do it. What were the GM engineers thinking when they designed it where you have to remove the bracket along with the alternator? Tonight I swapped it out - but this time left the rear bolt off. Anyone else just leave that rear bolt off?
06-20-2012, 11:47 AM #2
3 times = wow.
Is it the PS pump killing it (leaking on top of the alternator)?
No I haven't tried leaving the bolt out. I just cuss and make vulgar threats to GM engineers that design this.
06-20-2012, 05:05 PM #3
It's called the remanned blues.. jk
As long as the Alt does'nt vibrate as this is'nt good you can get away with it.
If the alt vibrates it will die quicker than before and possibly kick off the belt..
Personally if it was there b4 I'd put it back..
Take it from someone whom has changed the hardest altenator on the planet... LQ1Last edited by Smittro; 06-20-2012 at 05:08 PM.
06-20-2012, 05:46 PM #4
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
I did an alternator about once a year on my '94 Camaro 3.4. Gotta love remanufactured parts. On the other hand, it was a breeze to change since it was on top instead of the bottom.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
06-20-2012, 06:06 PM #5
- Mar 2007
- Henryetta/Tulsa Oklahoma
I'm on my 3rd, but I also have 227k miles. Wifey's little hands are...well, handy the last one I got was supposed to be a remannned, but a new AC Delco may have 'accidentally' made it into my box.
Handy hands, no nails were harmed during installation...
Sent using my telèfonoLast edited by Y2KArcticSS; 06-20-2012 at 06:10 PM.
06-20-2012, 06:17 PM #6
Swap out your K-member for a UMI tubular one and it'll make the next alternator change much easier.
06-20-2012, 07:04 PM #7
I have swaped 5 so far in the life of the car. The last 2 I took off the rear bolt and bracket. Haven't noticed any issues.
06-20-2012, 08:13 PM #8
- Jun 2011
- Branchville, NJ
06-21-2012, 12:57 AM #9
You guys don't even want to know (you can see it's location in my avatar) about LQ1 Alt changes..
You can't see the alt with engine in place.
It's bracketing is incoorperated with the trany/motor mount between the fire wall, trany, and engine.
Only way to even see it is to remove the inner fender well then pull the passenger axle,
and detach the strut to get it unbolted, then it comes out where the axle was.
The only thing to grab onto is the Alt pulley which of course wants to turn on you.
Almost all of it's bolts are "blind" and would seem GM had children working the Canadian lines as those seem to be the size hands you need to get it out..
I'll gladly install your LS1 alt if you'll do mine..thanks..lolLast edited by Smittro; 06-21-2012 at 01:01 AM.
Replacement Alternator ???
By Patsy57 in forum Stereo and ElectronicsReplies: 12Last Post: 11-14-2016, 06:45 AM -
Question: Alternator Replacement?
By lsgunner28 in forum External EngineReplies: 10Last Post: 03-10-2010, 02:10 PM -
1972 Chevy Nova Alternator Replacement - Mr. Amp -
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 12-04-2009, 08:10 PM -
Alternator Replacement Question
By Boat in forum General HelpReplies: 6Last Post: 10-30-2008, 03:28 PM -
By BlackLT1Z28 in forum LT1Replies: 14Last Post: 10-25-2007, 12:13 PM
