Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 88
  1. #21
    Member My00Z28's Avatar
    Sep 2010
    Holland, MI/Lima, OH
    2000 Camaro Z28 A4
    No one is flaming anyone. We are all giving the OP ideas for his build.
    Let's keep this civil or posts get deleted and thread bans are handed out. NO ONE IS DUMB IN THIS FORUM.
    No read the posts everyone is bashing my opinion and I never said they r dumb I said they r "being" dumb and if I get banned for my opinion that would be low.
    I guess back to the OP's thread!
  2. #22
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Well, then let the ideas commence. I for one want to see a V6 to V8 swap.
  3. #23
    Pittsburgh
    2008 Hummer H3
    To the OP:
    It would'nt be me if I did'nt mention this option also..
    OR THIS:
  4. #24
    North Jersey
    2004 GTO M6
    Eaton M90 in the top pic?
  5. #25
    Jan 2012
    Ft Meade
    RED
    1998 Camaro
    I appreciate everyones advice and tips on the swap, the 3.8 in the car is shot so a V8 swap is the direction I am heading. I have considered a 6.0 swap from a truck which would be a little more cost effective. I recently read a post on another forum it took this guy about 5 days to complete the same swap I am working on but he bought a donor car and making sure to see what connections need to repinned or modified for the injectors was a big part of the swap.
    (B) Will the stock control arms work on a after market k member a stock one of course would be cheaper but if I choose to spend the extra money I wasnt sure if it would work.
  6. #26
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by cade75 View Post
    Well many of the things on the 3800-II harness will just not work with the LS1.
    The injector harness only has 12 pins and you'll need 16 for the ls1 injectors.
    Also the LS1 has dual 2-wire knock sensors and the 3800-II has dual single wire knock sensors.
    As far as the after market K member to stock LCA's I can't comment.
  7. #27
    North Jersey
    2004 GTO M6
    I think your stock A-arms would work. You *MIGHT* have to swap over to stiffer springs, but I could be wrong.
  8. #28
    Pittsburgh
    2008 Hummer H3
    The input neck suggests an older style eaton, but it may well be a modded unit that was pieced together.
  9. #29
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Stock control arms do work on most aftermarket k members. usually the company will put that info in the description of the k member
  10. #30
    Jan 2012
    Ft Meade
    RED
    1998 Camaro
    Your right on the springs will need to be changed, the look would be killer but I am not trying to tear anything up by running a spring combo that was not designed for that weight. The injector harness is what I was uncertain about the guy had the hold car so I wasnt sure why he had to repin and mod the harness.
    If I go with the 6.0 truck motor and ecm what about the accessory harness the V6 shell is a base model so no power locks or windows.
  11. #31
    North Jersey
    2004 GTO M6
    If you want power accessories, you will need the wiring, the door lock actuators, the window motors and harnesses and the body control module. I might be missing something. If you want to keep the manual windows and doorlocks, then you don't need anything else.
  12. #32
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    The suspension will be fine.
    I'm 99% sure the springs are the same between LS1 and V6 cars. I say this because, believe it or not, the 3800 is heavier than an LS1. Iron Block and Iron Heads are not light by any means. Trust me, I've lifted both by myself, and the LS motor is slightly lighter.
  13. #33
    Madison, WI
    2001 Silverado Z71
    I've also swapped V8s into V6 cars without changing springs (80s GM G-bodies). It can be done and not be a major problem. Its something you can think about down the road if you want.
  14. #34
    Jan 2012
    Ft Meade
    RED
    1998 Camaro
    Thanks for the tip it will save some, Any suggestions on using a 6.0 cast iron block set up?
  15. #35
    FASTER THNA SPEEDINtICKEt BANDITO's Avatar
    A, A
    2002 trans-am
    I'm looking for a the torquer v2 and tfs 225cc heads...Looks good on paper but eh.
  16. #36
    Pittsburgh
    2008 Hummer H3
    These guys are right about the coil springs.
    The 3800 fully dressed is ~ 500 lbs or so, and the LS1 fully dressed is just under that.
    Sorry, had 3.4l v6 f-body on the brain for some reason.
  17. #37
    Pittsburgh
    2008 Hummer H3
    Ya I have a new set of 3800-II heads sitting here and they are heavy suckers.
  18. #38
    Jan 2012
    Ft Meade
    RED
    1998 Camaro
    Will the V6 drive shaft work for daily driving until I order the aftermarket one, or should I just go ahead and get a stock piece off of a Z?
  19. #39
    Pittsburgh
    2008 Hummer H3
    Should as long as it's the one piece steel unit and not the 2 piece.
  20. #40
    Laurel, Maryland
    2000 Grand Prix GTP
    You'll blow the two piece apart on your first real WOT pull.
    Get a single piece...steel is ok, aluminum would be better. I have my stock aluminum off my WS6 if you're interested.
  1. Trans swap for swap
    By [CJ] in forum Drivetrain
    Last Post: 08-12-2011, 12:11 PM
  2. Engine swap and computer swap
    By mrmiatanut in forum Computer & Tuning
    Last Post: 09-08-2007, 05:10 PM
  3. To Swap, or not to swap, that is the question.
    By HasselZ28 in forum Camaro / SS
    Last Post: 08-11-2007, 07:58 AM
  4. Replies: 6
    Last Post: 01-30-2006, 01:02 PM
