Results 141 to 160 of 213
10-06-2011, 03:39 PM #141
- Apr 2008
- Madison, WI
Yeah I can see the LM1/LM2 being the one I want. It just seems so much more handy and easier than the LC1. Well I think its time to start digging around in the garage for things to sell so I can get one.
10-06-2011, 04:47 PM #142
I just looked at Innovate's site -- it is the LM-2 "Basic" Kit listed for $349.00. Don't remember the price being that high, but it has been a while.
10-06-2011, 07:42 PM #143
Wow, that is a high price Jeff. I don't remember it being that much but I could be wrong, it's been a while.
You said LM-2 though?? I don't believe that was even around when I bought mine, Just the LM-1 was it.
Does the LM-2 have something better or more options??
10-07-2011, 01:14 AM #144this post is meant as a joke and in no way should it be interpreted as a serious or meaningful reply. The author of this post cannot be held liable for any damages, both emotional and physical, that may be incurred from the reading of this post. By acknowledging this disclaimer you hereby release the author from any and all liability
10-07-2011, 03:13 AM #145
10-07-2011, 03:14 AM #146
Cool! I can now see my sig for the very first time since the upgrade.
10-07-2011, 08:25 AM #147
10-08-2011, 03:13 PM #148
Another tank with around town driving,,,,,17.2 mpg on this one.
I'd say I made a solid MPG improvement with the SD tune. I'm getting repeatable results. Now for a long highway stint
10-08-2011, 03:15 PM #149
Darn thing is running good too for a truck. I was hanging neck and neck with a 5.0 fox body today. I think that guy was surprised to see a 4x4 with 33's staying at his door
10-18-2011, 01:26 PM #150
17.66 mpg again around town driving, very consistent.
I'm determined to keep this thread alive until a get a highway mpg reading I'm heading out on the highway Sunday for the first time since the SD tune.
10-24-2011, 08:22 AM #151
Finally hit the highway with this new SD tune. 20.28 mpg I had to drive faster than I wanted as I was running a bit late, going 75+ mph. So there might be more in it if I slowed down the cruise speed a bit.
I'm going to try a few tweaks in the light throttle cruise area too and see what I can pick up.
10-24-2011, 05:10 PM #152
- Apr 2008
- Madison, WI
Dang, that pretty good. Are you sure your speedometer/odometer is accurate?
10-24-2011, 06:16 PM #153
10-30-2011, 03:39 PM #154
Alot of driving this weekend. 22.39 mpg. Best so far. I don't think I will better that so I think I'm leaving the SD tune in as it is. Happy with the power and throttle response now. It drives much easier, and I get more throttle angle in 4th gear before the converter unlocks which is nice when climbing mild grades around here. That helped with MPG tremendously. That's where this 6.0 has an advantage over the 5.3 I almost went with,,,,,the 3.07 gear and 33" tires needs grunt.
I still need to relocate the IAT sensor and remove the MAF perminantly.
10-30-2011, 08:25 PM #155
I am so jelly. My RCSB 5.3 truck is still averaging 17-17.5 with mixed driving.
10-31-2011, 07:54 AM #156
I have just been playing around with my cruise speed on the highway. Since there are tons of mountains around with long grades, I found that cruising at 70 mph (or slower) was costing me gas. With 33" tires and 3.07 gears, it would constantly kick off the lockup converter to maintain speed. I got 20 mpg like that.
I found that if I cruised at 75-80 mph (speed limit is 75) the converter will stay locked up, and still maintain my cruise speed while going up hills. Just a sweet spot for the engine, slightly higher rpm where it has a little more grunt and keeps the converter locked. This got me 22 mpg.
I'm happy with it. Good enough for a daily driver in my book. No one ever suspects an old 72 blazer could do that
12-01-2011, 10:34 AM #157
- Thornton, CO
Any one have experience with transmission tuning?
The TBSS likes to drop itself into 1st gear around slower corners in neighborhoods. From maybe 15MPH. You let off the gas, and then when you lightly accel again it goes to first. It instantly drops into 2nd, but that shift makes me worry about the 4L70E.
12-01-2011, 10:54 AM #158
The only thing I did to my trans on my TBSS was replace the servos with ones from a Corvette trans (under warranty). I did have the same problem as you however, but just lived with it. Plus it was a lease, so I didn't really worry about it too much.
12-01-2011, 10:54 AM #159
Yeah, you can change the shift points up and down vs mph.
I actually had to change mine to make it do what yours is doing. Since I'm running 3.07 gears and a 33" tire, I wanted it to go to first gear when I slowed down for a turn.
I think I have mine set to downshift to first at part throttle or no throttle at 18 mph. That way the engine isn't lugging in second trying to pick up speed again. Seems to squirt around town better that way. Since it upshifts out of first at 25 mph part throttle, it works good for me.
Now when I install the 3.73 gears, I'll have to change that setting, probably tone it down to 10 mph or so, otherwise it will do what you are experiencing with the "back to first and quickly back to second" scenario.
12-01-2011, 11:40 AM #160
Obama, Romney Tweak Each Other In Swing States
By Ed Blown Vert in forum Political / Debate ForumReplies: 0Last Post: 10-24-2012, 04:50 PM -
HPTuners Pro
By 99bta6 in forum Parts Wanted / TradeReplies: 0Last Post: 03-18-2010, 03:16 PM -
OEM Radio Tweak
By Sarge in forum GTOReplies: 27Last Post: 01-23-2009, 05:36 AM -
Wanted: 99' Hptuners
By Mark8fish in forum Parts Wanted / TradeReplies: 0Last Post: 06-17-2008, 10:19 AM -
i got hptuners
By mrr23 in forum Computer & TuningReplies: 7Last Post: 12-01-2006, 01:35 PM
