View Poll Results: Like the Upgrade?
Voters
28. You may not vote on this poll
  • Yes
    10 35.71%
  • No
    6 21.43%
  • Hell No
    6 21.43%
  • Once I get use to it
    6 21.43%
Page 4 of 17 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 324
  1. #61
    I too have to dbl click for reply page... just something to get used to.
    All in all, I'm having fun just surfing the new format. There are some cool new features, and seems pretty user friendly.
    Also, the old "User CP" link is now called "settings" and is located on top right of page. Kind of an odd way to title it, but now that I know, it's pretty simple.
    Great job Ed!! Thanks for staying on this and getting us through it so quickly, I know it wasn't easy.
    Thanks -- I couldn't figure out where it went. I have been using the "Subscribed Threads" under the "Quick Links" tab.
  2. #62
    Omaha, NE
    2000 Z28 Camaro
    I was pissed at first, "what's the BS, I LIKE VB!!!" then I figured a few things out and calmed down.
  3. #63
    Orlando, FL
    Mean Black
    Looking good Ed. Great job.
    1998 TA 130k A4, LS6 intake, TunedByFrost, Airlid, AIR and EGR delete, Borla exhaust, front Eibach lowering springs, LS6 valley cover, UMI TQ arm, UMI LCA's, UMI panhard bar, Poly engine mounts, BMR relocation brackets, Blistein HD shocks and struts, Oil catch can, Autotrix window fix.
    Now I have an 2001 F150 5.4L
  4. #64
    Pittsburgh
    2008 Hummer H3
    +2 Album did'nt survive, but I am familier with this setup.. 60*v6.com has been using a similer setup for a while now..
  5. #65
    East of Cleveland, Ohio
    99 WS.6 - Modified
    One thing I have noticed, you can no longer space sentences. The site will move all sentences to follow each other.This sentence should be three lines down from the previous two, but it isn't.
  6. #66
    DFW
    '18 CTS-V
    '13 ZL1
    thanks ED for all the hard work you've been heading up with switching and updating the site. keep up the good work!
    2013 ZL1: °°590rwhp/576rwtq°°
  7. #67
    Omaha, NE
    2000 Z28 Camaro
    That's a big negative for me. It makes it easier to read.
  8. #68
    Join the PHK @ thephk.org Sommer86@6LE's Avatar
    Studio City, CA
    Not a fan of the new layout.... but i'll deal. Thanks for trying! I'm sure it'll get better.
    Join the PHK
    2009 LS1.com Calendar Car
  9. #69
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    Arizona
    383 Procharged & N20 Vert
    I will check into it
    Sent from my DROIDX using Tapatalk
  10. #70
    Aug 1999
    Arizona
    First Line
    Second Line
    Third Line
  11. #71
    99 WS.6 - Modified
    First lineSecond lineThird line
  12. #72
    Aug 1999
    Arizona
    What browser?
    1st
    2nd
    3rd
  13. #73
    99 WS.6 - Modified
    Something with my settings maybe?
  14. #74
    99 WS.6 - Modified
    Right now I'm on a droid x. I'll try my office pc in a bit.
  15. #75
    USA
    Velocity Yellow
    2008 Corvette Z06
    Eins
    Svei
    Drei
  16. #76
    Aug 1999
    Arizona
    Oh, I will try it on mine
  17. #77
    99 WS.6 - Modified
    Changed the text option.
    Let's see if this helps.
  18. #78
    99 WS.6 - Modified
    Guess I can't use the full editor with the phone.
    I switched to the standard editor. Seems to be working fine now.
  19. #79
    Junior Member taylorsdad0607's Avatar
    May 2011
    Arlington, TX
    RED
    2000 SS
    I still have no idea what all that meant.
  20. #80
    99 WS.6 - Modified
    Quote Originally Posted by taylorsdad0607 View Post
    Under the general settings tab, there is an option to choose the type of message editor you want to use. Mine was set to the full editor. Apparently, this causes an issue with the spacing, when posting from my Droid X. Set to standard editor, the problem is gone.
  1. Upgrade Engine, Upgrade Transmission
    By clovenhooves in forum Firebird / WS6
    Last Post: 12-22-2009, 09:07 PM
  2. Move to Texas? Big change/Big move. Your opinions?
    Last Post: 06-15-2008, 08:04 PM
  3. do you move out of the way or wait for the other guy to move
    Last Post: 05-26-2007, 05:49 PM
  4. Simple Upgrade Solutions - Oem Upgrade 2003 Bmw X5
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 11-16-2006, 08:18 AM
