Thread: Just got back from the dyno
03-30-2011, 05:05 PM #1
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
Setup
TrickFlow As Cast 220cc Cylinder Heads- 3.90 Bore
Fully Assembled Including .650 Lift Springs
Mill to Desired Compression-61cc
Hardened Pushrods
228/230 .588/.592 112 LSA Camshaft
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Front Cover Gasket
Front Cover Seal
Waterpump Gaskets
GM Crank Bolt
Powerbond 25% Underdrive Pulley with Gates Belts/GM Bolt- F Body
Comp Drop In Hi Performance Lifters
Katech C5R Timing Chain
Melling Hi Volume Oil Pump for LS Engines
SVO 42lb/hr Fuel Injectors
GM MLS Exhaust Manifold Gaskets
Poly Motor Mounts
Kooks 1 3/4 LT's
LS6 Intake
TSP 3'' True Dual Exhaust
426 HP 413 TQ
What you think?
03-30-2011, 06:05 PM #2
Very Nice. Did you have a run before all those adders? Curious how much overall gain. 429 RWHP is pretty sweet. Time to show it off at the track!
2000 WS6 TA #2946 - A4, Best 1/4: 12.5s @111mph.
SLP LTs, 228r Cam, SY 3500, Shift kit, LS6 intake, underdrive pulleys, lid, p&p TB, Borla w/ cutout, Pro-kit springs, poly all around, Hotchkis suspension, 3.90 gears, tuned.
03-30-2011, 06:45 PM #3
Nice numbers. Especially the torque. The duration between intake and exhaust on that cam is short. I usually see much lower torque numbers in that situation. Wonder if it was the volume of the runners that helped it, or the milling to 61cc? Bet it pulls HARD.
04-09-2011, 07:34 AM #4
That has got to be one of the smoothest a/f lines i've seen. Very nice.
04-19-2011, 02:37 PM #5
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
Nice numbers! Did you have to fly cut the pistons to run those heads?
04-19-2011, 10:27 PM #6
- Nov 2006
- Broken Arrow, OK
Who did the tune, Ed Wright?
01-05-2012, 04:34 PM #7
01-05-2012, 07:07 PM #8
Nice! Congrats Sir.
Just got back from the DYNO
By Ant71130 in forum Firebird / WS6Replies: 9Last Post: 05-07-2012, 10:10 AM -
Just got back from the dyno!!!!!!!!!!!!!!!
By RS_SS69 in forum Rocky Mountain MembersReplies: 13Last Post: 03-22-2006, 05:53 PM -
Just came back from the DYNO!!!!
By adham in forum Dyno InformationReplies: 35Last Post: 02-20-2006, 12:34 PM -
By Jersey_TA in forum Eastern MembersReplies: 8Last Post: 12-25-2005, 04:14 PM
