Results 41 to 53 of 53
Thread: Racetronix pump install in pics
04-10-2011, 06:55 PM #41
good write up. sticky vote. I tried dropping my tank but mine is metal and couldn't clear the neck. I even dropped the whole rear end and no clearance. it was still stuck. It was getting caught at the opening for the neck to go to the gas cap door. I ended up doing the trap door.
04-10-2011, 07:06 PM #42
Nice write-up. Thanks for sharing and good to see you got it all swapped out
04-11-2011, 05:10 AM #43
- Jan 2010
- texas
silver- 2000 formula
04-11-2011, 10:34 AM #44
congrats on the sticky. I'm sure you could bud. I was just tired of messing around with it for hours. Then on top of that i had a leak in the plastic tube from the racetronix pump so after all that I needed to drop the tank again, no thanks.
I also hit the float wire and it got abit out of adjustment. now a full tanks shows abit less than the full mark in the gauge. Not a big deal.
12-01-2012, 04:57 PM #45
just did mine too today. was actually really easy. i forgone the dropping the tank and went straight to cutting the trap door.
I have a 98 Ta so its a touch different.
heres some nice pics to go along with your build
12-03-2012, 08:08 PM #46
- Jan 2010
- texas
good pics of the 98 install !!
02-06-2013, 06:18 PM #47
Very informative with great pics. Not sure why I missed this thread when it was originally posted.
02-09-2013, 11:11 AM #48
- Jan 2010
- texas
got yours swapped out yet jeff?
there is a special tool to get that funky star ring off the top of the gas tank......i did not have it then but i have 1 now......thanks ebay
its a J-39765Last edited by sjsingle1; 02-09-2013 at 11:15 AM.
02-09-2013, 12:06 PM #49
lol ^ one benefit, of very few, of having a 98 f-body lol now i wish i could say the same thing about the PCM
02-09-2013, 03:53 PM #50
I'll probably get started on mine in the next few weeks. Been going strong on the Olds lately.
07-28-2013, 12:49 PM #51
I'll add 4 things.
1. 98's have a different pump and instructions. Make sure you get the right pump for your car.
2. When you go to reinsert the assembly it will fight you. The float wants to hang up on baffle in the tank.you have to angle it or use something to bend the assemble. It has a spring so you can move the bracket.
3. Those rubber feet are a Major PITA to get on.
4. If you are dropping the tank, like I did, you need one more person. Have the tank with the least amount of fuel possible. For every gallon you're adding approx. 6.6 lbs per gal. (14 gals = about 92 lbs of dead weight)Last edited by SMWS6TA; 08-31-2013 at 09:16 AM.
07-29-2013, 09:01 PM #52
^^^^^ all very true. it took me a few trys to figure out what the hell was going on when I tried to get my pump back in. its has to go in at a weird angle back towards the back of the car. its an awkward process lol
Also, if it has been pointed out, the first picture in the set I provided has the Racetronix box with 98 specific product number if that helps any
08-31-2013, 09:09 AM #53
Looks like I need to order filter socks before I get started. I just read through the entire thread again in preparation.
Help: New racetronix pump not pumping
By ponyslayer in forum General HelpReplies: 14Last Post: 11-27-2011, 05:21 AM -
Racetronix pump whinning
By JayTA98 in forum General HelpReplies: 6Last Post: 07-24-2010, 03:29 PM -
Racetronix pump priming?
By JayTA98 in forum General HelpReplies: 25Last Post: 04-27-2010, 01:54 PM -
Racetronix Fuel Pump and Hotwire Install Instructi
By WS6ICK in forum General HelpReplies: 17Last Post: 09-13-2008, 10:36 AM -
98 LS1 Racetronix fuel pump
By underated98z in forum Parts For Sale / TradeReplies: 0Last Post: 04-12-2007, 11:51 AM
