Results 41 to 60 of 97
Thread: Step By Step - HID Light Upgrade
07-20-2011, 09:14 AM #41
- Oct 2007
- Florence, AL
07-20-2011, 09:24 AM #42
- Apr 2010
- IN
pics when finished
07-20-2011, 11:33 AM #43
- Oct 2007
- Florence, AL
07-23-2011, 11:20 AM #44
- Oct 2007
- Florence, AL
Well, my replacement parts came in yesterday, but I didn't have any time to finish the install, but found some time this morning between playing plumber and chef.. LOL.. I haven't been able to aim them yet, since it isn't dark enough and I'll have to drive somewhere to do it since my driveway is at an angle.
Here are a few pics..
Brackets with the housings installed..
Installed and on..
07-23-2011, 11:29 AM #451998 TA 130k A4, LS6 intake, TunedByFrost, Airlid, AIR and EGR delete, Borla exhaust, front Eibach lowering springs, LS6 valley cover, UMI TQ arm, UMI LCA's, UMI panhard bar, Poly engine mounts, BMR relocation brackets, Blistein HD shocks and struts, Oil catch can, Autotrix window fix.
Now I have an 2001 F150 5.4L
07-23-2011, 12:28 PM #46
- Oct 2007
- Florence, AL
Thanks..
I think it'll look really good when I get the high's in there..
07-23-2011, 04:40 PM #47
07-23-2011, 09:05 PM #48
- Oct 2007
- Florence, AL
LOL.. Yeh, I think it'd look sweet.. I'm just starting to run out of room for ballasts, so I dunno what I'll do..
I was able to take some shots of the cutoff..
This one is before I did too much adjusting.. I had to run down to a local gas station to get some level ground to adjust the lights. I was "mid-adjust" when some local rednecks came out and started acting like there was going to be an issue, so I left..
I went down to another location that I thought might not end up in someone getting shot and took these..
I basically adjusted it until I stopped getting flashed by trucks. Cars never seemed to mind, but taller trucks sure had an issue with it at first. I guess I need to see if there is an official way to adjust the beam for optimal effectiveness..
07-24-2011, 08:54 AM #49
07-24-2011, 10:13 AM #50
- Apr 2010
- IN
07-24-2011, 06:49 PM #51
- Oct 2007
- Florence, AL
11-11-2011, 08:08 AM #52
- Oct 2007
- Florence, AL
I got a PM asking what these looked like at night, so I thought I'd post the video here as well..
Projector Retrofit
11-12-2011, 05:23 AM #53
Tram,
That is a really nice, modern looking mod. You should offer it up as a kit! Well done, mate!
11-12-2011, 12:36 PM #54
- Oct 2007
- Florence, AL
12-26-2011, 01:46 PM #55
Problem with Install!!!!!
Wow - I have a major problem! The Fogs are melting my housings - both sides.
These are the 880 HID kits. On my Passenger side the whole bulb housing is melting the rear relector and housing so that the bulb is pointing towards the driver side. On the Driver side, the lens is melting the center, I cannot see what is happening to the housing.
Here are some pics:
Passenger Side:
Driver's Side:
Shoot, I thought I had done a really tight install. Anyone have a clue as what is going on?
HELP!!!!!
GershLast edited by dagersh; 12-26-2011 at 01:48 PM. Reason: Bigger Pics
12-26-2011, 02:44 PM #56
- Jan 2009
- North Jersey
What is the heat range of the fogs you are running?
12-26-2011, 02:52 PM #57
- Jan 2009
- North Jersey
I can only assume the ignitor for the right pic is possibly too close to the lens causing the fogged look. Left pic looks like possibly vibration related.
Possibly a switch to a cooler heat range set and glass-housed projectors would suffice?Last edited by cammed goat; 12-26-2011 at 02:55 PM.
12-27-2011, 04:36 AM #58
12-27-2011, 04:39 AM #59
12-27-2011, 11:58 AM #60
Oh, that might make some good sense.
Good point. I thought I had ordered 35W, but maybe I did not realize they were 55w.
Shoot. Anyone know where to get replacement or even better glass/metal housings?
Thanks!!!!
Gersh
Step By Step: Tight Locking Trans Dipstick
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-10-2014, 02:10 AM -
Step By Step - Chrysler 440 Six Pack Electric Choke
By Ed Blown Vert in forum General HelpReplies: 1Last Post: 06-24-2014, 05:11 AM -
Step By Step - Starting A Vintage Top Fuel Dragster
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 11-06-2013, 05:10 AM -
Brake System Maintenance - Flushed Out - CHP Step By Step
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-29-2011, 02:30 AM -
Chevy 630 HP Small-Block Engine - Rockin'- Step By Step - CHP
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 10-19-2007, 04:04 AM
