Results 21 to 40 of 292
06-22-2010, 03:58 AM #21
14" -- I was kind of surprised after we bought the car, but then checking a bit it seems that a lot of cars from this era have 14" wheels.
06-22-2010, 04:49 AM #22
06-22-2010, 06:09 AM #23
06-22-2010, 11:00 PM #24
09-06-2010, 05:26 PM #25
Talked to the builder last week and the machine work is done on our block. We are not in any hurry, so we probably won't be going up to get it until later this Fall. In the meantime, the wheels have been painted and the tires are mounted up. The chassis is back on its wheels for the first time -- that was a good feeling. I took the intake over to a friend's and used his bead blast cabinet to start cleaning it up -- I have sharp stuff in mine so it was just easier to go for a ride.
Pic of the W-31 intake before I started cleanup:
09-06-2010, 08:49 PM #26
09-07-2010, 12:18 AM #27
This is like an instant replay. My nephews finally got their dad's 70 W-31 out of grandma's garage where it sat for 26 years. The anti freeze had all crystalized and the intake heat risor was full of corn from a mouse. The engine got a freshen-up and the interior a rehab job. Body and gold paint still excellent. It was out and about for awhile, the nephew got married and it hasn't been seen since.
Good luck with your project.
09-17-2010, 05:04 PM #28
Still have some work to do on the intake. Bead blasting cleaned up most of it, but it has a mottled appearance now. All my other intakes have either been powdercoated or painted in the past... this one has to stay natural aluminum for originality. Any suggestions?
09-17-2010, 06:38 PM #29
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Lots of elbow grease .... I would maybe suggest Mothers polish. I've used it to polish intakes before - but they were a machined aluminum. I'm not sure how well it would work on a rougher textured aluminum. You might consider a good aluminum rim cleaner also - it may help clean it up with a little less work. But you gotta be careful with them - some could make it look worse.
09-17-2010, 06:42 PM #30
10-14-2010, 08:33 AM #31
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
10-14-2010, 11:59 AM #32
Tough crowd...
Ok -- I bead blasted the intake and then went over it with a fine wire cup and cone. It took it back to a natural finish with just a bit of shine. I have spent the last 3 nights sandblasting small parts and sorting through what needs to go to the engine builder so we can hear this puppy roar some time next month on the dyno. I am also awaiting an order from Fusick's for a new dipstick tube, oil fill cap and some othe rmiscellaneous small parts that were beyond saving. My new dilemma is the crud on the bottom of the valve covers -- not sure how I am going to clean it all out as it has a long shallow baffle. I do not want to be dropping junk into my fresh engine.
10-14-2010, 12:45 PM #33
10-14-2010, 06:09 PM #34
10-14-2010, 06:24 PM #35
Here's a shot of the intake all cleaned up and ready to ship:
It looks as if a valve cover was replaced at some point -- the really cruddy one actually has some blue paint on it rather than the gold it should have. You can see the baffles and why I don't dare toss them in the blast cabinet:
10-14-2010, 08:28 PM #36
The intake looks a lot better.
10-15-2010, 03:19 AM #37
That blue, (if it's a baby or powerder color) is 1970's GM engine paint prolly.. I used to associate that color with smoggers.. Also blast those in a bead blaster and you'll most likely have the trouble I had with the first TDC block and heads.. I loved how it looked but I'll never bead an engine block again. Looking good tho Jeff! Good luck! iirc, from jet fire 330-455 all had the same (~) factory rocker covers..
10-15-2010, 03:38 AM #38
I forgot about your issue with the TDC. Before I ship the intake, it is getting washed and blown out real good. I believe you are correct -- the valve covers are the same for those engines.
10-15-2010, 07:24 AM #39
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
you could use kerosene (sp) and a brush i have done that before.
10-15-2010, 09:35 AM #40
Question: anybody familiar with the oldsmobile aurora.
By dav-02ws6-m6 in forum General HelpReplies: 25Last Post: 07-03-2012, 02:44 AM -
I need some '69 Oldsmobile Cutlass parts! (help!)
By FasstChevys in forum Classic MuscleReplies: 5Last Post: 10-27-2011, 12:06 PM -
F/S or Trade 1970 SS396 El Camino Project
By H8tulooze in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-01-2008, 06:42 AM -
Any oldsmobile forums?
By TARZAN in forum Almost Anything GoesReplies: 5Last Post: 05-31-2007, 02:59 AM -
1970 oldsmobile cutlass convertible forsale
By z-28lover in forum Vehicles For Sale / TradeReplies: 0Last Post: 10-25-2006, 10:32 AM
