Results 41 to 56 of 56
Thread: Bye-bye cruise module
06-22-2012, 09:27 PM #41
Just remember, a peice of Scotch brite and can of Krylon satin black Bbq spray paint are your friends
06-30-2012, 09:11 AM #42
- Apr 2010
- Alabama
Anyone know how to delete the cruise control? I don't ever use it so I see no need for it. I was reading that you need a different throttle cable. Does anyone know what is required for this?
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-30-2012, 11:23 AM #43
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
I deleted mt cruise and traction control. You will need a cable for a non traction control car. I have a extra cable, it is brand new GM tags still on it. PM me of you are intrested.
06-30-2012, 12:10 PM #44
07-16-2012, 08:02 AM #45
pajeff02...
how many plugs did you use?
07-16-2012, 02:32 PM #46
If you are referring to this post: http://www.ls1.com/forums/f52/bye-by...ml#post2258804 I used three of the plugs with the slotted pins through which the zip ties were run. I did use a couple of additional black plastic plugs to fill the other open holes in the fenderwell.
07-25-2012, 05:25 AM #47
07-25-2012, 05:21 PM #48
That works too.
07-29-2012, 04:03 AM #49
- Apr 2012
- virginia
blue- 2001 trans am
looks great, i want to do this
07-29-2012, 04:29 AM #50
It's easy to do and really helps to eliminate some of the clutter.
08-02-2012, 06:49 AM #51
what did yyou use to extend the cruise control wire?
08-02-2012, 06:51 AM #52
08-02-2012, 07:30 AM #53
I did solder in a section of wiring if I recall correctly. Once you have the module relocated, figure out where your wiring will run and then plan for an extension just a bit longer to give you some slack. I prefer solder and shrink tube, however, crimp-style butt connectors will also work.
08-02-2012, 08:41 AM #54
- Jun 2011
- Branchville, NJ
Now you see'em, now you don't. Good job. It looks great.
08-02-2012, 09:21 AM #55
08-02-2012, 02:33 PM #56
That works too. All my wiring went underneath - that may be why I extended it. Just been too long to recall the details.
Cruise control module
By az gt eater in forum Appearance SectionReplies: 5Last Post: 05-25-2011, 05:34 PM -
cruise control module
By 1MileCrash in forum General HelpReplies: 21Last Post: 04-21-2009, 10:55 AM -
For Sale: abs module,cruise module,water tem gauge
By sammy burks in forum Parts For Sale / TradeReplies: 5Last Post: 06-02-2008, 05:38 AM -
Cruise Control Module Removal?
By RAMAIR02 in forum General HelpReplies: 0Last Post: 04-18-2008, 12:31 PM -
By Formul8or in forum Computer & TuningReplies: 0Last Post: 04-17-2006, 01:14 PM
