Results 21 to 40 of 56
  1. #21
    mercersburg pa
    hugger orange
    2004
    Looks good Jeff!
    I was thinking about making a C-channel cover for the frame rails and mounting the coils under it so all you would see is the wires going to the plugs
  2. #22
    Quote Originally Posted by mark21742 View Post
    Looks good Jeff!
    I still haven't had time to check out the relocation kits that were referenced earlier. Not sure if that would work on an F-body with the heater hose setup -- but with your fabrication skills anything is possible.
  3. #23
    Member jerri311's Avatar
    Jul 2009
    Houston
    2002 Trans Am WS6
    Good job. I'll have to try this.
  4. #24
    On the wire hide mod, I did do something a bit different than the sticky. Rather than utilize velcro to secure the wire run, I installed three (3) plastic plugs that have an open slot through the top of the wheel house. I was then able to insert a zip tie through the slot and cinch the wiring up tight to the underside of the wheel house.
    The plugs I utilized are Dorman P/N 45470 of their Body-Tite line of products. They are labeled for use on Nissan & Toyota, but worked perfectly. To see the plug, simply enter the P/N at http://www.dormanproducts.com. The direct link I tried to post would not work. I found these on the racks at our local Advance Auto Parts.
    It does help having a black car as the plugs blend in well. I also plugged the remaining holes left from relocating the ground wire and cruise module with a standard smooth head body fastener. I really like the clean look:
  5. #25
    TA Nut BlackTAWS6's Avatar
    Waco, TX
    2002 Trans Am WS6
    Looks good.
  6. #26
    Thank you. The cables and wire harness have bothered me since we bought the car. Moving them, deleting the secondary air, and ditching the helmholtz resonator have really cleaned up the look of the engine bay. I considered moving the hood release cable as well, but that doesn't stand out so much.
  7. #27
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    Well, it's easy for him, what with his small hands and being able to climb into his engine bay.
    is he the guy from the burger king commercial?ahahahahaha
  8. #28
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i have the thunder racing kit on my camaro. it's works good but i wouldn't do it again. there is a company that makes valve covers that actually cover the coils and you just see the wires going to the spark plug. it looks so clean and makes your valve covers look like the tall ones.
  9. #29
    I saw a set of aluminum LS1 covers in the most recent Jeg's. Looks like they work exactly as you described in your post. So far, I do not believe anyone has put up pics of covers like that in the "post your engine bay" thread. Wouldn't mind seeing a set installed up close.
  10. #30
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i'll get one but warning it is very dirty lol.
  11. #31
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    here not mine but looks the same.
    http://www.ls1lt1.com/forum/showthread.php?t=1549
    only thing that looks different is i have my coils going out instead of in like his i may switch it later after seeing this one. but it get tights back there.
  12. #32
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i have these but i still haven't put them on.
    http://www.jegs.com/i/GM+Performance...34398/10002/-1
  13. #33
    Hard to believe there is that much room back there. Thanks for the pics.
  14. #34
    Junior Member 00ss4780's Avatar
    Weaverville, NC
    00 SS
    That is awesome. I haven't seen that done before. I'll have to go and try it tomorrow. Thanks.
  15. #35
    Apr 2010
    IN
    how did you get the wires to run up that high towards the cowl??
  16. #36
    Marylandistan
    2001 Trans Am (sold)
    Quote Originally Posted by BashamWS6 View Post
    Swapping in longer wires.
    Looks good Jeff. Wish I could do this to mine but lack the motivation. All you gotta do now is ditch the whole AC system. I knew a guy who had done the wire mod, no cruise control, coil pack relocation and AC delete. Looked pretty cool, just like an empty engine bay with an ls1 in it.
  17. #37
    I would have to look back at the start of this thread, but I believe I did extend the wire harness a bit. If I wasn't such a wuss with heat and humidity I would ditch the AC just to lose all that weight.
  18. #38
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    When I did it, I did the wire hide mod at the same time...this allowed me to snip the wires for the TCS from the bundle and run them to the new location. No wires were cut.
  19. #39
    Junior Member JadedBird's Avatar
    Jun 2012
    Kentucky
    WS6
    compared to cars on here... my engine bay looks like someone threw up on it
  20. #40
    A little time and elbow grease makes a huge difference. Once cleaned, it is pretty easy to keep it that way even if you drive it regularly.
  1. Cruise control module
    By az gt eater in forum Appearance Section
    Last Post: 05-25-2011, 05:34 PM
  2. cruise control module
    By 1MileCrash in forum General Help
    Last Post: 04-21-2009, 10:55 AM
  3. For Sale: abs module,cruise module,water tem gauge
    By sammy burks in forum Parts For Sale / Trade
    Last Post: 06-02-2008, 05:38 AM
  4. Cruise Control Module Removal?
    By RAMAIR02 in forum General Help
    Last Post: 04-18-2008, 12:31 PM
  5. Cruise Control Module
    By Formul8or in forum Computer & Tuning
    Last Post: 04-17-2006, 01:14 PM
