Page 1 of 3 123 LastLast
Results 1 to 20 of 56
    Bye-bye cruise module
    Thanks to Jaison, I did something tonight I never would have thought of. Get your mind out of the gutter -- it's an appearance mod, not something you do with a box of Lucky Charms.
    I have never liked the cables strung across the engine bay. I didn't know you could do anything with them until Jaison mentioned hiding the control unit behind the PCM. I hate to admit it, but he was right -- it fits perfectly and could not have been easier to do.
    I already had my PCM out as it took a trip to Frost recently. All I did was unbolt the cruise module, removed the bracket and applied some self-adhesive foam to prevent rattles. The plastic cable bracket that attaches to the AC hose was also removed. I then removed a bolt in the firewall and used it to secure a cable clamp with the eyelet parallel to the ground.
    I then inserted two (2) nylon zip ties through the cable clamp and carefully worked the module into place. I ran both zip ties around the motor so that they act to hold the housing up and snugged them down. The cables in the engine bay then tuck beneath the cowl and are essentially out of sight.
    I will most likely do the wire hide mod as well. If not, I simply need to extend the harness a bit (which I may have to do even with the hide mod) and plug the cruise conrol module back in. This little mod cleans up the look of the engine bay quite a bit.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Nice job Jeff.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Yeah, I did that mod a few months ago, and I love it!!!
    Good job.
    appearance mods on a dirty engine is like winning the special olympics. LMAO...that's for the lucky charms bit bro!
    Just a bit dusty from the garage. Once the weather breaks she'll shine again.
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    this is awesome, I always knew about this mod but never thought it was so "user friendly" Now that I see how simple it is its DEFINATELY on the list! thanks again
    Started the wire hide mod this evening. Had to go buy a 1-3/4" holesaw as I do not have one. As soon as the teeth hit metal it jumped and I broke the center drill bit. Fortunately, I have lots of those, so I just installed another one and made it through on my second attempt.
    I'm not finished, but it looks a whole lot better already just having the wiring out of there. Tomorrow, I'll run the wires through and install a rubber gromet with a little weatherstrip adhesive. Will have to figure out what to do with the ugly holes left in the top now. Yes, the car is dusty...
    This is a good thread, and I couldn't remember where I saw it.
    This would be really useful as a sticky
    Quote Originally Posted by Bouvers View Post
    Agreed and added to museum
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    If Jaison can do this. Anyone should be able to.
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by SandmanWs7 View Post
    Well, it's easy for him, what with his small hands and being able to climb into his engine bay.
    I extended the wire harness for the cruise control module tonight as I was re-connecting everything from underneath. The wire hide mod is just plain slick imo. I did not measure, but the pieces I spliced in were probably 14-16" in length and that gave me plenty to reach the cruise module. No butt connectors, the ends were twisted, soldered and covered with shrink tube.
    very nice work man! Really looking forward to doing this to my baby.
    Pittsburgh
    2008 Hummer H3
    Nice work Jeff! I've been thinking of moving my ignition module (coil packs) to a new location so they don't cover the valve cover but I can seem to think of a place to mount them without chopping the harness up..
    I agree that they need to go on our car too -- especially after I took the time to polish the rocker covers. The hassle of relocating the coil packs is part of what motivated me to buy a set of FRCs.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    I'm planning on painting my covers for a alittle more bling under the hood. But that stupid coil location sucks. The base of the pack mnt, is almost as long as my valve covers and it's also slightly wider than the covers too. It's location imho is going to just cover all my appearance work ugh..
    If you're concerned about hiding your coil packs, there is a company out there that produced a kit that relocates them under the cowl. I can't remember the name though.
    Wait.........WHAT??!! LoneGunman's Avatar
    Jun 2006
    Central PA
    Hugger Orange
    '99 Camaro Z28
    Thunder Racing sells them. $210 for the whole shootin' match. I don't know if FRC's would fit with this kit though.
    I will have to check them out, thanks for the info. I do like the look of the FRC's, so for now I will keep the coils where they are. Could be next winter's project though.
    Tonight, before sliding the PCM home, I also mounted the harness for the cruise module. I didn't want it hanging free back there where it might create a rattle. The metal tab on it simply folds over and I used a small washer along with an existing bolt on the AC housing to mount it. Looks like this now:
    Senior Member 00z28bubba's Avatar
    las vegas, nv
    2000 Z28
    nice
  1. Cruise control module
    By az gt eater in forum Appearance Section
    Last Post: 05-25-2011, 05:34 PM
  2. cruise control module
    By 1MileCrash in forum General Help
    Last Post: 04-21-2009, 10:55 AM
  3. For Sale: abs module,cruise module,water tem gauge
    By sammy burks in forum Parts For Sale / Trade
    Last Post: 06-02-2008, 05:38 AM
  4. Cruise Control Module Removal?
    By RAMAIR02 in forum General Help
    Last Post: 04-18-2008, 12:31 PM
  5. Cruise Control Module
    By Formul8or in forum Computer & Tuning
    Last Post: 04-17-2006, 01:14 PM
