Results 61 to 80 of 239
Thread: bigger better faster build
02-20-2010, 02:54 PM #61
- Jan 2010
- Phoenix, AZ
Red- 2000 Trans AM
LOL Im jealous. Its gonna end up costing me close to 8. i was thinking maybe get a short block from kentucky speed and assemble the rest. so you didnt have to do the alternator bracket tap? that intake looks sick, I'll have to use it on my next build. i cant leak details but it'll be a gm old body and it wont have spark plugs. Did you have to put a new rack and master cylinder? why? I've never put a block together from custom parts i've only done rebuilds, do u tihnk its necessary to mill the heads and block if everything new?
02-20-2010, 05:14 PM #62
I think my altenator bracket is different than the F-body, it has 3 bolt holes and I only used 2and did not drill/tap for the 3rd hole, but the alt also has a bracket coming off the rear of it that bolted right in too.
I didn't need the manual rack, but wanted it (one less power draw on the motor). I went full manual brakes so I wouldn't have to worry about lack of vacuum with a bigger cam.
I'd always check to be sure all the mating surfaces are true before assembling, but most of time they should be fine... I milled and ported the hell out of my 241s to get as much out of them as possible without having to buy top shelf heads right now. Milling raises the compression and boosts efficiancy (going from 10:1-11:1 gives a 3-4% increase in torque)
02-20-2010, 07:10 PM #63
I really like the "old school" nature of your build -- manual brakes and steering. Less weight, less drag on the engine, something you don't see guys doing these days on newer cars. Very cool.
02-20-2010, 07:22 PM #64
02-21-2010, 04:38 AM #65
Back years ago I had several older cars, everything from a 49 Packard, 67 Caprice, 66 valiant, 67 Catalina, 67 and 69 Chevelles.
still have the 69 Chevelle in a tent at my parent's house for a future project. I already have it chopped and channeled down around a 4x4 S-10 blazer chassis and floor with an Olds Bravada AWD transfer case... When done I'll have my classic looking lowered down street car, but the advantage ultimate off the line traction
Number 29 of 303 Saab Sonett3's build in 1970, converting it to RWD and using the drivetrain out of the 289 66 Mustang project "Hostang".
Currently working on project "Hostang", a build for my 70 year old mother. Its a 66 Mustang chopped and channeled down around a modified 96 Honda Civic floor, suspension, and drivetrain. When finished she will have her front wheel drive fuel injected, turbocharged 66 Mustang that get 30+ mpg, close to 300hp, and can safely be driven all year round.
I like building them and driving them...I don't want the car driving me
02-21-2010, 06:39 AM #66
Wow! That an impressive list of off the wall builds. If I ever get down your way there will be a knock at your door.
02-21-2010, 06:59 AM #67
02-22-2010, 07:21 PM #68
02-22-2010, 08:32 PM #69
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
that is one very busy gto. i don't think i could cut on mine like that. good luck. i can't wait to see it finished.
02-23-2010, 04:45 PM #70
- Jan 2009
- North Jersey
It's gonna be weird not seeing the TRG paint scheme anymore.
02-23-2010, 04:47 PM #71
This things gonna be nasty
02-23-2010, 04:52 PM #72
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
02-24-2010, 12:49 AM #73
Putting it back together is the easy part, making the 1st cut was definately the harest part mentally....after your fenders and quarter are laying on the floor in 10 pieces each you kinda have to keep working on it lol
The new paint job here in a month or two will be brite but really tone it down.
02-24-2010, 12:52 AM #74
02-24-2010, 05:55 AM #75
- Jan 2010
- Phoenix, AZ
Red- 2000 Trans AM
Mark your an automotive genius. Too bad your a country away, I pay you to help me work on my car.
02-24-2010, 06:19 AM #76
02-24-2010, 06:31 AM #77
- Jan 2010
That offer open to anyone?
02-24-2010, 08:29 AM #78
02-24-2010, 08:33 AM #79
- Jan 2010
Sweet, but knowing my luck I'd get busted for transporting alcohol across state lines lol.
02-24-2010, 11:57 AM #80
AMD's new FX chips let gamers build faster PCs at lower pric
By Ed Blown Vert in forum Computers / GamingReplies: 0Last Post: 10-23-2012, 04:30 PM -
434ci Small-Block Engine Build - The Bigger Mouse
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 02-03-2012, 11:00 AM -
500CI Chevy LS1 Engine Build - How To Build A 500C
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 02-17-2009, 07:10 PM -
will going bigger rims/tires make faster? stock to 275+
By greatwhiteZ28 in forum Wheels and TiresReplies: 6Last Post: 08-27-2007, 05:23 PM -
Is the A4 really faster than a M6
By q1234567890 in forum GTOReplies: 6Last Post: 03-26-2006, 07:54 PM
