Results 41 to 60 of 110
Thread: 1974 Chevrolet Corvette L-82
12-21-2009, 11:30 AM #41
12-21-2009, 11:59 AM #42
Put a jack under the differential and get the rear tires off the ground -- then grab the tire and see how much slop you have. There should be some play, but not excessive. As to the clunking noise -- it would not surprise me if the exhaust is hitting on the tunnel in the crossmember. Each pipe goes through a hole in the crossmember that supports the transmission. Before I replaced the entire exhaust system, ours had a fairly good "clunk" in it that was a metal on metal sound. Grab your tailpipes (make sure they are cool first) and wobble your exhaust around a bit -- see if that reproduces the sound.
12-21-2009, 12:06 PM #43
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
i actually had the exhaust replace from the cat back this weekend...i looked under the car while it was on the lift and all the pipe from the front to the back is outside of the frame, so i dont think that is the issue...although i suspected it before i had exhaust fixed...(on a side note, it does sound damn good now with 2 1/2" pipe with no mufflers)..but i think i may have a bad shock on the drivers rear. maybe the half shaft is hitting something on that side from it sitting too low?
12-21-2009, 12:09 PM #44
Could also be a lower shock mount that has broke or worked itself loose. Lots of stuff can bang around underneath -- keep looking and I am sure you will find it.
12-21-2009, 12:26 PM #45
12-21-2009, 12:47 PM #46
- Oct 2009
pewter- 99 trans am
hey jeff you got any pics of the underside of your car? and the engine bay? id like to check that out.
12-21-2009, 12:48 PM #47
12-21-2009, 01:04 PM #48
Thank you for your clarifacation. I only owned that car for three years and it spent most of that time in the air.The "Posi" was another issue as was the Radiator,Steering Control Valve,Emergency Brake Assy,Half Shaft U-joints,Drive Shaft U-joints,Tilt Telescope Steering Colume.The list is almost endless.To me it was lucky that I can do my own work,otherwise the labor alone would have killed me.It was fun,but when the time to dump the "Money Pit" came,I had no regrets.I replaced it with an 84 Z-28 that I still own today.
12-21-2009, 01:10 PM #49
12-21-2009, 02:03 PM #50
12-21-2009, 03:00 PM #51
Here are the only two decent underhood pics that I have. I am fairly new to the whole digital camera thing, so the majority of the restoration pictures are on print film. First pic shows the engine after I pulled the intake back off to powdercoat it. Decided to make it a mix of "new" and "old" as it now has Vortec heads. Second pic is from this spring after the new radiator unexpectedly took a crap on my garage floor. That was not a lot of fun, but it allowed me to clean up a bit more of the overspray from the paint job. I don't have any good pics of the undercarriage I can post.
12-22-2009, 12:33 PM #52
- Oct 2009
pewter- 99 trans am
i like the powdercoat...hey so is there a certain header that fits in the c3's or is it just a general longtube header? also is there a way to rebuild the headlight setup or what? mine go up in very slow motion...i suspect a vaccum leak but i checked the hoses and they look ok.
12-22-2009, 12:42 PM #53
The headers are Dynomax ceramic coated, made to fit the C3 -- I had to slightly clearance the bracket for the shifter interlock on the firewall to get them in from underneath -- other than that, they fit great.
Headlights are a PITA on these cars. Your vacuum source is located on the back of the intake manifold and probably includes a check valve and filter. The most probable leak is at the canisters - there is a rubber boot on the rod that is not too bad to replace. Also check the hoses where they attach to the canisters and to the diverter valves (which are mounted under the front header panel. I have a new switch for ours -- on startup our headlights go up and down all by themselves.
12-23-2009, 04:09 AM #54
- Oct 2009
pewter- 99 trans am
one other question...how much power are you makin? and does the stock drivetrain hold up well to a lot of power?
12-23-2009, 04:15 AM #55
12-23-2009, 05:02 AM #56
Check the little manual switch that's under the steering column.With mine,a previous owner must have used it a lot and it would leak in just one position.So the headlights would go up really slow and retract the same.If you manually left them up on mine,eventually one then the other would retract because of the leak.
12-23-2009, 09:29 AM #57
- Oct 2009
pewter- 99 trans am
i was not aware of this switch...guess im still learning about this car..
jeff- yea the half shafts seem to be whats makin the clang sound im hearing...perhaps some new u-joints in those......i plan on replacing the shocks this weekend....maybe that will tell me more....also i would like to find a few parts at a decent price....anyone know where to find the instrument cluster/radio housing fairly cheap? i have aftermarket radio in mine which i dont mind but id also like to have and uncut origional. also need a driver side t-top...i know those aint cheap for sure....but a tree limb fell on it during the hurricane and cracked it..its leaking....also some goood replacement window motors....center cap for the stock wheel...carpet, door panels ect....my interior isnt bad but id like to switch to black interior..and also looking for stock steering wheel.....damn thats a lot of stuff i want and didnt realize until now.
12-23-2009, 10:39 AM #58
I always forget about that switch too. We lucked out and have a Corvette restoration place and salvage yard about 20 miles from my house -- Gee's Corvettes. The owner has been great to deal with and has always come through for me on whatever I needed. Too funny -- we had a tree branch fall on ours during a storm and it put a good size hole in the top of the right front fender. Took care of that when the car was painted 3-4 years ago.
12-24-2009, 06:25 AM #59
08-22-2011, 06:04 PM #60
Trying to get the idle issues sorted out on the Corvette this week so we can put some miles on her this year. When I started the restoration, the engine was adorned with a Holley Q-jet replacement carburetor. I quickly found that neither a regular Holley or Carter style carb would fit under the stock air cleaner. I really wanted to retain this air cleaner as it is a cowl inducted piece and just looks mean with the seal ring setting in place. Not having any spare Q-jets laying around the garage, I ordered a Jet Stage II from Summit. So far, I have been less than impressed with it. On the run in stand, the engine ran and idled great with a Holley handling the fuel delivery. I switched over to the Jet Q-jet after installing the engine in the car and have had issues with wandering idle, stalling, lean mixtures, and backfiring. Interestingly, the mixture screws really do not seem to do a whole lot for helping matters. We even pulled the intake back off the engine to make sure we did not have a vacuum leak causing issues.
Prior to tonight, I had only removed the top of the carb to check things over. During that tear down, I noticed light shining through the dome next to the primaries and found what appeared to be a gouge in the casting. I epoxied that shut, made some adjustments to the height of the primary metering rods and tried running it last year. Although the engine idled better, it still exhibited signs of being lean and wandering. After removing the carb this evening and taking it about 85% apart, I have found a loose epoxy plug in a well to the side of the primaries and quite a bit of dirt and grime in the base, as pictured. Also, the primary throttle shaft on the passenger side appears to be a bit too loose. I inspected the base and it does not have a bushing kit installed. To say that I am less than impressed with the quality of Jet's rebuilds is an understatement -- I would have been better off starting out with a junkyard carb and building it myself.
1974 Chevrolet Chevelle - Rides
By Ed Blown Vert in forum Classic MuscleReplies: 0Last Post: 06-14-2012, 04:30 PM -
1971-1974 Chevrolet Corvettes - Remember When...
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 05-18-2010, 02:50 AM -
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 05-11-2010, 01:20 PM -
FS: 1974 Corvette
By Tonik in forum Vehicles For Sale / TradeReplies: 2Last Post: 04-03-2007, 06:12 AM -
1974 Chevrolet Chevelle Malibu Classic
By golem72 in forum Vehicles For Sale / TradeReplies: 3Last Post: 03-10-2006, 01:21 PM
