Results 1 to 18 of 18
Thread: JL install pics
    UNC Charlotte
    2000 Chevrolet Camaro Z28
    JL install pics
    my camaro z28 system, im 20 yrs old & did EVERYTHING myself...im currently in college studying electronic engineering....at some point in life id love to have my own car audio shop:
    system:
    Kenwood Excelon KDC-592 head unit
    Audiovox MT Commander XM Satellite Receiver
    STINGER ( speaker wire, 4 gauge power, dist blocks, etc.)
    Dynamat in needed areas...
    JL Audio TR Series 2-way components (front doors)
    JL Audio TR Series 2-way co-axes (rear seat side panels)
    JL Audio 10W1 v2 4ohm subwoofer
    JL Audio Slash Series 300/4 full range amp
    JL Audio Slash Series 250/1 mono block amp
    rear well amp rack ...designed and built by me
    fiberglass stealth sub box (.95 cubic in.) .....also designed fabricated by me
    enjoy:
    UNC Charlotte
    UNC Charlotte
    also i know the cars FILTHY in pics...car since has became garage queen w/ 90k miles and the fast mods have began...she also got a 3day cleaning.......2nd all that extra wiring under the amps has since been cut...hadnt had a chance to tune the amps.
    Junior Member Octavain's Avatar
    Aug 2008
    NW, Arkansas
    1998 Camaro
    This is the sweetest set up I've seen! I want a set-up like yours so I don't have to sacrifice my t-top holders!!! Do you know where I can pick-up something like yours???
    -Aaron
    Mods: SLP Flowpac Cold Air Induction Package, 160 Thermo, TB bypass, SLP (Clutch, Pressure Plate, Flywhell), Skip Shift Elminator, UMI (SFC, Tower Brace, LCA, Torque Arm, Panhand Bar), no cats, Moser 9" w/ 3.89 gears, 5.0 short throw, Strano Springs, Koni single adj, '94 OEM ZR-1 wheels
    Member fieropope's Avatar
    union mo
    01 formula
    damn fine lookin system .that amp rack is exactly what i was thinkin for my setup but you,ve blown my plan out of the water . Its safe to say that you could make some money off of selling those amp racks. KUDOS!
    Aug 2008
    NW, Arkansas
    1998 Camaro
    Agreed! I would buy one!!! And one the sub-box too!
    UNC Charlotte
    id thought about it...if their was enough interest
    USA
    BLACK
    Z/28 LS1
    Great job!!! Wish I lived near you-I would pay you well to do my Z. I don't trust these car audio places.
    UNC Charlotte
    Quote Originally Posted by LETHALxLS1 View Post
    yeah i dont trust audio shops either.....the cars cleaned up now and the wires have been hidden.....if i can just get off my lazy ass ill get some better pics
    California
    Charcoal
    2002 SS K&N FIPK
    Hopefully you'll kiss and tell...
    What's up with the stealth sub fiberglass boxes. How did you do that? Is it ported? It doesn't look like fiberglass. My only guess would be to lay in plastic, fill in with foam, let the foam set, then use this as a form for laying fiberglass over. Looking at it, I'm pretty sure I'm wrong. Hopefully this isn't an ancient Chinese secret. It's an OUTSTANDING installation, and just what I was looking for, but right now it's a mind boggling mystery!
    UNC Charlotte
    Quote Originally Posted by leitthouse View Post
    first, its a sealed box and it is fiberglass....and would be extremely difficult to make if you havent had any experience w/ glassing.....i didnt make a mold or anything...just made it right in the car...taped up the area, layed down aluminum foil, taped over that, then soaked that w/ resin applied a layer of glass, soaked on some more resin...then allowed that to dry overnight....the next day i removed it from the car and added 4 layers of glass and resin...then using 3/4 mdf i made the faceplate(i routed the edge so the sub is flush mounted)...and proceded to apply that to the mold using glass and resin.....after that i used a mix of resin-body filler to seal up the inside of the box...and another thin coat on the outside...after this had dried i applied a black rubber coating to the outside...wrapped it in carpet and dropped in the sub...also for the wires i just used a spare terminal cup i had laying around.....found a flat spot on the side, dremeled out a hole and glassed it in
    UNC Charlotte
    -note as soon as i get time ill do a better step by step write-up w/ pics
    Junior Member krazykarl454's Avatar
    quakertown PA
    i love the amp rack. u've solved my problem. and i was thinkin the same thing for a sub box sincle i need closer to 1 cu ft for the 12" MB Quart im lookin to run.
    Pittsburgh
    2008 Hummer H3
    Wow! That has to be the most excellent use of such a confined space I have ever seen. SweeeeeeeT
    Love that color by the way..
    Member mild2wild's Avatar
    Apr 2009
    E of Rochester NY
    Orange/Black
    1999 Camaro SS
    That's awesome lookin', well done!
    I'm a CHICK with a gun and an LS1, nuff said...
    1999 CAMARO SS #81 of 4829
    LS6 intake * 3.73's * Borla catback * L/T Headers
    ZO6 18's * MSD/NGK * SLP Lid/Bellows * KYB Adjustables
    Summit Racing Springs * Fresh paint/interior in 08
    Member LgndKller20073's Avatar
    Denver,CO
    2001 Firebird
    how did you mount the amp rack? I have a similiar set up that I had bought from a website a few years back, but they had me use self tapping screws to screw it into the car. Well after having to wire and rewire and things from upgrading stuff, my amp rack has began to fall apart. I like the way you seemed to have mounted it. Let me know what you did. Also, where did you get the carpet from? Thanks
    UNC Charlotte
    Quote Originally Posted by LgndKller20073 View Post
    You can see in the pics, I used threaded galvanized steel bolts, you remove the rear tail light panel , drill the holes the bolt them down....then you have2 make brackets on the back of the amp rack to secrue it to the bolts......i work at a car audio shop....thats where the carpet came from....you just have2 look for a stereo shop near you....or you can get it online somewhere
    Junior Member ORION WS6's Avatar
    Aug 2009
    Ocala, Fl
    2000 Trans Am WS6
    Awesome set up. Nice job with the install. Keep up the great work.
  1. LT1 rad install in pics
    By sjsingle1 in forum External Engine
    Last Post: 04-14-2013, 01:19 PM
  2. CTS-V Install w/ pics
    By Wesman in forum Suspension and Handling
    Last Post: 06-13-2011, 11:43 AM
  3. Header Install in Pics (Pt 2)
    Last Post: 05-09-2010, 02:14 AM
  4. INSTALL progress pics -- rear well box for 12" -- PICS
    By fredmr85 in forum Stereo and Electronics
    Last Post: 05-28-2007, 12:37 PM
  5. SLP Lid install pics
    By bellboa1 in forum Camaro / SS
    Last Post: 04-24-2007, 02:28 PM
