Results 21 to 40 of 50
Thread: What are the chances?
05-25-2009, 04:54 PM #21
Move away from California
05-25-2009, 05:39 PM #22
05-25-2009, 07:21 PM #23
05-25-2009, 09:11 PM #24
unfortunately i cant guarentee anything but how can he prove that your motor didnt break on you, seeing as how the vin isnt on the block just on the car. i dont see anything wrong with trying it. just mention the ecm came with the whole engine package if he says something about the ready sensors.
05-26-2009, 05:11 AM #25
05-26-2009, 11:12 AM #26
- Nov 2008
- Riverside, California
Black on Black- 2001 Trans Am WS6
Look, getting advice from people who don't live in California is a major crap shoot. Last time I checked California had the most stringent smog laws. Check the following link and the website for the California BAR. http://www.bar.ca.gov/80_BARResource...uidelines.html. This website may answer some of your questions.
In order for a smog station to be certified as an Inspection Only Station, they have to follow the rules very closely. The BAR has undercover inspectors who test these stations every day. They will yank their certification in a heart beat. Also the machines link directly to the BAR so It's very difficult to go shoping for a station that will pass you.
I also believe if you mention engine swap, that will flag you for a more thorough inspection. My advice is to get the EGR fixed if you can.
California is not a Muscle Car friendly state when it comes to emissions. Also the BAR and the CHP as well as the DMV also have links on their web sites to report cars that smoke or cars registered out of state. They do follow up on these reports. Remember, it all generates money to the state and right now they are hurting for it.
Once again, good luck...
05-26-2009, 01:10 PM #27
05-26-2009, 02:45 PM #28
- Feb 2006
- Orange County, NY
Tape a $20 to the intake where the egr goes.
05-26-2009, 04:36 PM #29
05-26-2009, 06:08 PM #30
05-26-2009, 07:02 PM #31
Ok, here's the low down. I have to know this shit because I am a licensed smog tech in california. My number one question is do you have a check engine light on? If you do then you will fail right away. Yes the BAR 97 smog machine has a checklist. The VECI under the hood will tell the tech what emmissions equipment is under the hood. If you have an EGR visually we will check for that as it is required todo a visual inspection. If yoou pull the sticker off, we have an ECS manual that will tell us what you need under the hood. If you had an engine swap you are required to have the proper emissions equipment from that year vehicle so if you do not have the 00-02 smog equipment you get knocked. The BAR 97 has an OBDII connection to check to see if all but 2 of your monitors have ran. EGR is one of the continuous monitors so you may have an issue there. Also the fact that you are missing an EGR you can tell on the ASM once you get the 25/25 loaded test or the 50/15 because your NOX will be up and it will cause you to fail because your EGR reduces the NOX emmisions off idle. I just checked my ECS manual and the 02's do have an EGR. So hopefully this info will help you figure out what you need to do. Any questions let me know.
05-26-2009, 07:06 PM #32
05-26-2009, 07:17 PM #33
- Nov 2008
- Cincinnati
09 Sierra Denali AWD- 2001 T/A WS6 NBM
i took mine off also since living in Ohio we dont need them....got mine laying in garage....need it ??? lol
05-26-2009, 07:50 PM #34
05-26-2009, 07:51 PM #35
Thanks for all the help phoenix, I will take all of that into consideration. But like what Y2K asked, will i not pass emissions then because of what you said. When I look at the sticker under the hood, no where on there does it have the word or letters EGR......also I do not have a check engine light on......
05-26-2009, 07:55 PM #36
what did you do to get all those tickets?
05-26-2009, 08:16 PM #37
05-26-2009, 08:45 PM #38
You will not pass emissions because of the NOX readings and the visual test. If the door sticker and the VECI is missing the year is easily determined by the 10th digit of the VIN. W,X,Y,0,1,2 are for 98-02. Don't go shop to shop because every time you hook to the BAR 97 a record is transferred. Worst case scenario, the smog tech is a dick, deems your car as unsmoggable and sends you to the Ref. In that scenario, everything has to be stock on the car or a carb approved sticker. If any of you guys have any questions with SMOG let me know. I currently do have my smog license but I can't smog vehicles because I don't work at a smog station. But if you have any questions about codes and diagnostics let me know also because I do work for Snap on Diagnostics. So code questions, weird gremlins, I can get info on
05-26-2009, 09:00 PM #39
I'm not too familiar with the 2000 to 02 VECI's I have to look at one. But I believe it does not say EGR, it is a different type of system to reduce NOX. It is a valvle near the brke booster that functions as an EGR and most techs know what it is. Hence I said Most But it is there. The SES light, the roicedure to check it according to BAR is to go Key on engine off, verify the SES light turns on as a bulb check, start the vehicle and verify the light goes off. If your light does that then it's all good. If you have a pending or stored code, you are good to go. If all but 2 of your monitors have run then you are good. The only thing I see as a fail is high NOX emissions. EGR is meant to cool your combustion temps to reduce NOX. If you run high octane gas you might get away with it if the tech is real lazy and doesn't do a full visual
05-26-2009, 10:55 PM #40
what are my chances
By davidz28 in forum Kill StoriesReplies: 27Last Post: 10-27-2010, 06:00 PM -
What are the chances of 2
By 02sunsetorangeZ in forum Kill StoriesReplies: 10Last Post: 07-30-2010, 03:22 PM -
What's the chances of...
By SurfaceGod in forum Firebird / WS6Replies: 48Last Post: 07-14-2010, 05:33 PM -
2 GT'S my chances?
By 02sunsetorangeZ in forum Kill StoriesReplies: 129Last Post: 02-22-2010, 11:31 PM -
what are my chances?
By cam02ss in forum Almost Anything GoesReplies: 16Last Post: 02-24-2006, 02:20 PM
