Results 1 to 11 of 11
Thread: Nice Stock Grill Insert
05-15-2009, 09:34 PM #1
- Jul 2008
- Jacksonville, FL
Red- 2000 SS '89 IROC-Z
]For those that don't want to buy a new insert, and either want to repair their stock insert from bracket damage, or just want it to look better, this is for you.
Remove the insert. Plastic clip-ins on the sides and bottom, and plastic bolt things on the top three. It will look like this without it.
After that, wash the stock insert. Then fill the holes with either bondo, or plastic repair caulk. I used plastic repair caulk, and it was runny, sort of messy, but worked beautifully. Tape the back of the holes, and fill.
Then sand it. When they molded the piece they had it texturized so that it has that rough feel/look. I wanted a smooth, glossy texture. I started with 120 grit, and had a drill attachment which helped speed it up. From 120 I went to about 220, or finer if you want. The sand paper will tear it up pretty good, but don't worry. Should look like this when you get the shit off.
After that then sand a lot more. Once you feel that it is smooth, then use glazing putty and a spreader to fill in any other pits or holes that you either created or missed. Let it dry, then sand some more with fine sandpaper. I used 2000 grit, and it got smooooooth. It will look like this. As you can see I didn't put it in the slotted parts. I didn't really sand their either, looks pretty cool.
After it's real smooth, then spray with primer. Then sand with more 2000 grit, then put on another coat. Then sand again.
After it's nice and primed and smooth, then you're ready for paint. I did mine black, but seeing another color would be pretty sweet.
After drying, you can either paint the inside of the CAMARO, or you can buy inserts for it.
http://cgi.ebay.com/ebaymotors/Camar...RCHQ3aUSQ3a105
Mine is without inserts currently. Also, I broke my plastic bolt (things) so I had to glue it back in.
[/QUOTE]Last edited by levityinc3; 05-20-2009 at 04:52 PM.
05-15-2009, 09:46 PM #2
- Nov 2006
- Broken Arrow, OK
Added to the museum sticky, thanks for the 2nd thread.
05-15-2009, 09:50 PM #3
05-20-2009, 03:35 PM #4
- May 2009
- Toronto
SOM- 2002 SS
05-20-2009, 03:44 PM #5
05-20-2009, 04:53 PM #6
05-20-2009, 04:55 PM #7
05-20-2009, 04:56 PM #8
05-20-2009, 04:57 PM #9
05-20-2009, 07:36 PM #10
- May 2009
- Toronto
SOM- 2002 SS
Ahh I mistook the insert for flat plugs that would fill the holes. It's actually a sticker to fill the 'camaro' i think.
I was hoping someone would make plugs to fill the holes so we can paint em and make it look good. I'm still trying to come up with something simple to use to fill them.
05-20-2009, 08:05 PM #11
SLP Grill Insert- Problem
By levityinc3 in forum General HelpReplies: 3Last Post: 04-24-2013, 06:08 PM -
Alternative to Grill Insert
By levityinc3 in forum Appearance SectionReplies: 81Last Post: 07-25-2009, 06:23 PM -
Stock 98-2002 Camaro hood, spoiler, grill insert, t-top shades (grey), and springs
By SENN13 in forum Parts For Sale / TradeReplies: 0Last Post: 10-22-2007, 06:57 AM -
Ram Air Grill Insert Stainless
By Smkn_TA in forum Parts For Sale / TradeReplies: 4Last Post: 10-04-2007, 04:57 AM -
WTB SS Hood insert/grill
By ProwlerZ in forum Parts Wanted / TradeReplies: 2Last Post: 02-07-2007, 05:19 AM
