Results 1 to 20 of 24
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    tire size equivalents
    here's a quick list of tire sizes for the f-body. with these tire sizes, there is no need to recalibrate the PCM because they are all the real close to the factory height.
    245/50-16 = 25.7"
    245/45-17 = 25.7"
    275/40-17 = 25.7"
    315/35-17 = 25.7"
    245/40-18 = 25.7"
    275/35-18 = 25.6"
    285/35-18 = 25.9"
    315/30-18 = 25.5"
    335/30-18 = 25.9"
    245/35-19 = 25.8"
    285/30-19 = 25.7"
    295/25-20 = 25.7"
    what you do is shorten the sidewall of the tire to accomodate the larger diameter wheel. all will be same height, just in different widths. then, depending on the offset and width of the wheels you buy, will determine if you need to 'clearance' the inner fenderwell or not. then, depending on how much you lower the car, and offset/width of the wheel, will determine if it will hit the outer fenderlip.
    Member wabmorgan's Avatar
    Feb 2006
    Objects in mirror are losing
    Artic White
    96 Formula Firebird
    So, how tall is a p285/35-18???
    I ask becase I think I would rather be a little taller than shorter.
    orlando, fl
    2014 camaro 2ss/rs
    25.9" tall. you can go to tirerack.com and find all these answers.
    Junior Member uwilluz's Avatar
    Feb 2006
    michigan
    black black pewter
    89,00 LPE WS6,02 LPE WS6
    i was told there was no need to reprogram the pcm unless you had 5mph difference over stock which would effect your abs. that would allow a few more tire sizes. last year i ran 235 40 17 fronts and 275 40 17 rears with no problem. 265 40 17 fronts this year, no problems
    83 Firebird SCCA Race Car, 89 WS6 T5 SCCA Race Car 00 Lingenfelter WS6 T-Top 6spd Transam, race suspension, baer brakes, 02 Lingenfelter WS6 vert 6spd Transam, 1971 LT1 Vert Corvette, 06 Ext Cab Z88 5 spd Canyon, 08 Z71 Ext Cab Sierra
    orlando, fl
    2014 camaro 2ss/rs
    i put my 26" ET streets on my black car with some worn down 245/50-16 tires on the front. so, guessing they were about 25.5" tall. ABS light came on and when braking it activated the ABS system. pain at 120 mph after going through the traps at the track.
    Alcohol Injected PaganEgyptian's Avatar
    Knoxville,Tn
    1999 Pontiac Firebird
    Post
    26" is factory hieght for the V-6 side of the house.
    though you can use the V-8 size option.
    215/60R16 = 26.1" * not recommended due to wide wheel sizes on 98+, ok on pre 98's with 16x7 wheels
    235/55R16 = 26.1"
    255/50R16 = 26.1"
    285/40R17 = 26.1"
    Optional fitment
    225/60R16 = 26.6" * good as snow tires and extended highway use for +mpg's
    245/50R16 = 25.7"
    245/45R17 = 25.7"
    275/40R17 = 25.7"
    315/35R17 = 25.7"
    335/35R17 = 26.1" * drag only on an 11" wheel
    Junior Member 2000silvervette's Avatar
    Aug 2006
    Mo.
    2000 corvette coupe
    I've got a c5 coupe with 275/40/18 on back, I'd like to put some dot drag radials on the factory wheels, I've found some nitto 555 r in 285/35/18, will they go on and ride good, or are they not going to match the wheels. running a 13.0 now hoping to get in to the high 12s with good traction at launch, running stock run flats now, and I've looked a some factory size falkens, but would rather have the street legal drag tires.
    orlando, fl
    2014 camaro 2ss/rs
    wil lbe about 1/2" shorter. will go on the wheel.
    Aug 2006
    Mo.
    2000 corvette coupe
    Sounds like they'll work alright, I believe I can live with them being a little shorter, thanx for the info.
    On my new CCW wheels I am planning to go with 18x10s up front and 18x11s out back. For the rear tires I am going to be using 295/35/18s which are 26.1" in diameter. I am considering 2 different sizes for the front, either 275/35/18 which is 25.6" or a 255/40/18 which is a 26".
    My question is, if I use the 275s up front would the .5" diameter difference affect the ABS or anything else?
    TIA
    Preston
    Painted manta stripe
    orlando, fl
    2014 camaro 2ss/rs
    .5" is iffy. most likely won't. do they make a 265/40-18 in the brand you are looking to get? it is 26.3" tall.
    Negative, its either the 255/40 or a 275/35. I could go with the 255/40s and only be off .1". Going that route would save me $60 as well, just not sure how the 255s would look
    NH
    2016 Silverado Z71
    1999 Camaro SS #1437
    mrr23, were abouts in o-town i'm in kissimmee?
    orlando, fl
    2014 camaro 2ss/rs
    i just moved to ocoee. so, about 30 minutes away.
    NH
    2016 Silverado Z71
    kool
    i got friends there and APK
    orlando, fl
    2014 camaro 2ss/rs
    i have two fellow club members in kissimmee as well.
    Iowa
    So if you want to run radically different tire diameters front/rear can the PCM be programmed to compensate? What's the best software to do that?
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by tinindian990 View Post
    none that i'm aware of. all you can do is take the fuse out for your ABS, so it won't activate on you.
    Iowa
    Ok thanks. At least there's a way to get around it.
    Member joker's Avatar
    Feb 2006
    North Carolina
    2002 Pontiac Trans Am WS6
    how do you feel about 295-35-18's all around ?
  1. Question: Tire size?
    By Madison in forum Wheels and Tires
    Last Post: 12-20-2011, 10:48 AM
  2. tire size questions to the tire gurus!
    By vonskeezy28 in forum Wheels and Tires
    Last Post: 04-30-2011, 09:01 AM
  3. Tire Size?
    By TA98 in forum Wheels and Tires
    Last Post: 01-07-2011, 01:22 PM
  4. tire size
    By hotrod44_4u in forum Wheels and Tires
    Last Post: 12-09-2009, 06:13 PM
  5. Question: Tire size
    By 98warbird in forum Wheels and Tires
    Last Post: 11-02-2008, 03:33 PM
