Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 64
  1. #21
    Retired Outlaw Sum Bitch
    By the way boys and girls with flat tappet valve trains...this is what you want right here....turbo/blown/nitrous boys....this is your lucky day....Esters have replaced organic friction modifiers here....very high tech very expensive stuff that flat ass works....thus my excitement over the Pennzoil thing....but I will be giving this stuff a go head to head with Shaeffers Series 7000....
  2. #22
    Member CompSyn's Avatar
    Pacific NW USA
    Thumbs up PC Membership
    I will be testing this stuff. My PC expired CompSyn so I need to renew under you....so I guess I can go to your website and renew my PC and order a couple of cases?
    Sure thing Sarge!
    Just go to http://competitionsynthetics.com and scroll down until you see the Preferred Customer link. Click on that and then you’re redirected to the secure Amsoil storefront where you see the heading “Become a Preferred Customer”. Under the heading you will see “CLICK HERE” in yellow highlight. Okay! Almost done! This is kind of long winded process, but it’s what we got to deal with here. Now you see the heading “AMSOIL Preferred Customers SAVE! Right next to the Services pop down tab below you will see either PC Membership or Oil Analysis Services. Select the PC Membership and choose either the 6-month trial or the one-year membership.
    Voila!!! Your done and now you can buy as many cases of Dominator racing oil as you like. Signing up like this not only allows you to purchase Amsoil products at cost like before, but also allows us at Competition Synthetics to get the credit for your purchases... Now Everyone’s Happy!
    BTW. One of my customers experienced an issue during this process with his Mozilla Fire fox web browser. A simple fix was for him to switch to Internet Explorer and he was able to sign up for the PC Membership without issue.
    Thanks in advance Sarge!
    CompSyn
  3. #23
    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    40 weight in a tight clearance environment actually raises the oil temp believe it or not! Do you have a oil temp gauge? Oil pressure gauge? How are you determining what various viscosities are doing in your motor? Based on what?
    I thought I'd be raising the temp but with a 160 thermostat wouldn't be a problem given the viscosity. I did not realize I was impeding lubrication with oil that was too thick. It was strictly seat of the pants and why I thought I'd ask before I went too much further. I have no other gauges yet.
    I have less than 10 miles on the oil and its coming out this afternoon.
  4. #24
    Member Texas Jack's Avatar
    Central Texas
    Cyclone Grey
    2006 GTO M6
    Whats' the deal with the ester based oil and where do you get the Sheaffers oil, old man learns something new every day. Thanks'
  5. #25
    Quote Originally Posted by The Silver Goat View Post
    People tune and tune to the finest detail when we are talking about A/F knock retard etc. but they do not tune their oil. You are correct.....too thick and your lubricity goes down and your oil temps go up. It is a exercise.
  6. #26
    Quote Originally Posted by Texas Jack View Post
    Esters hold up much better than dino base oils. Where in Texas are you and I can tell you where to get Shaeffers.
  7. #27
    Member anniversary30's Avatar
    Illinois
    White/Blue
    99 Trans Am
    OK, i'm trying to learn and,understanding about half. Which oil are you recomending sarge? Shaeffers or the AMSOIL or either 1? I have castrol 10-30 synth in it now. I have replaced everything so far,the top half of the motor the trans getting done now and the rear end has been done. If I can keep from blowing up the bottom end for a while this would be a major bonus. I was once told oil is cheap insurance so don't skimp.
  8. #28
    Central Texas
    Cyclone Grey
    2006 GTO M6
    Sarge, LLano county. Thanks'
  9. #29
    Quote Originally Posted by anniversary30 View Post
    Amsoil/Shaeffers/ or Pennzoil Platinum. You were told correctly.
  10. #30
    Here is your distributor for Shaeffers.
    Agro Fuel Inc Hwy 190 E
    San Saba, TX 76877 (325) 372-5713
  11. #31
    Apr 2009
    Newnan, GA
    Cosmos Purple
    2004 Pontiac GTO
    So Sarge Mobil One isnt good oil? Pennzoil Platinum is better?
  12. #32
    Mobil1 is good oil. Better returns with Pennzoil Platinum. If that changes we will make adjustments to recommendations as formulas change.
  13. #33
    Pacific NW USA
    Post Revised PDS
    FWIW - Pennzoil Platinum did just have a formulation change.
    New Pennzoil Platinum Technical Data Sheet – revised April 2009 pdf link
    And some of the physical properties have changed a bit.
    CompSyn
  14. #34
    Central Texas
    Cyclone Grey
    2006 GTO M6
    Thanks', Sarge!!
  15. #35
    Quote Originally Posted by CompSyn View Post
    CompSyn
    Yup. I love the change!
  16. #36
    Apr 2009
    Newnan, GA
    Cosmos Purple
    2004 Pontiac GTO
    What do u mean by better returns? you mean cleaner, better engines, more power, or what?
  17. #37
    Illinois
    White/Blue
    99 Trans Am
    Thanks sarge, next change i'll do either the amsoil or the penz.
  18. #38
    Quote Originally Posted by 04cosmos View Post
    Used Oil Analysis coming back from the lab reflecting lower wear metals and higher TBN retention.
  19. #39
    Apr 2009
    Newnan, GA
    Cosmos Purple
    2004 Pontiac GTO
    gotcha. sounds like im using pennzoil on my next oil change.
  20. #40
    queens n.y.
    2006 gto
    so ,do you think royal purple is all hipe.im looking for the best for my engine. 2006 gto. heads and cam done to it.
  1. Pennzoil Ultra??
    By blackSS01 in forum Almost Anything Goes
    Last Post: 03-07-2010, 10:56 AM
  2. Pennzoil Platnuim swap????
    By driftpin in forum General Help
    Last Post: 02-22-2009, 08:32 AM
  3. $1.99 Pennzoil Platinum
    By Sarge in forum Almost Anything Goes
    Last Post: 08-25-2008, 04:06 PM
  4. Pennzoil Platinum $.99 a quart
    By lonewolf37 in forum General Help
    Last Post: 11-04-2007, 11:56 AM
  5. Free Pennzoil Platinum
    Last Post: 11-02-2007, 10:39 AM
