Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Member herculesrider1's Avatar
    TX
    '00 TransAm RamAir WS6 M6
    Is it very difficult to separate them? I would rather not tape the injector holes if I don't have to. Separating them would keep overspray away. Do you recommend separating them or just taping off the injector holes before painting?
    Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
  2. #22
    98 T/A w/ mods, 00 FBVert
    Smooth, Filled and Painted my FAST Intake
    Yes. it is bolted together and has a gasket seal. when you put back together use blue locktite on the nuts so they don't vibrate off per FAST.
    I didn't bother taping off injector holes. use some WD40 or light oil on o rings and it inserts easy
    00 FB Vert - Stock
  3. #23
  4. #24
    Don,
    Have you fitted the 102 yet?
    You'll need to clearance the water pump in order for the 102 throttle body to sit flat.
  5. #25
    TX
    Don,
    My bad Scott. I thought you were referring to the stock intake, not the FAST 102. Sorry dude. But I appreciate the good advice as always!
  6. #26
    You can also paint the stock intakes too. I did that one too. Hated the fade black it had, so I painted it High Gloss Black too.
    Use adhesive promoter as well as a good quality paint. I used Duplacolor for single color coats and clear.
  7. #27
    TX
    Well, just tonight I taped my intake off to do just that! I plan on painting it gloss black after sanding off the 3 round circles on each runner with 180grit, then 300grit, then 600. Adhesion promoter comes after the sanding, correct? Or after the primer? Then topping it off with a couple coats of clear with some wet sanding inbetween. Want her slick as glass...!! Thanks man~!
  8. #28
    After sanding..
    this is how I did mine.
    wipe down all with degreaser and cleaner for paint prep with non lint towels.
    spray adhesive promoter according to directions
    primer, 2 med coats, 2 light coats. sand if needed. if you sand wipe again with cleaner.
    paint, 2 med coats, 2 light coats. wet sand if needed, clean again.
    clear coat, 3 med coats, 2 light coats.
  9. #29
    TX
    After sanding..
    Awesome information. I soaked the intake in 1:1 strength Simple Green and Super Clean for several days, then soaked it in water to get all the degreaser off, shaking it every now and then. Amazing how clean it looks inside and out! What paint prep cleaner are you referring to? Brake Cleaner? Alcohol? And I assume you are referring to micro fiber towels? Thanks!
  10. #30
    I use Rustolium Wax and grease remover.
    O'Reilly sells it for $8
  11. #31
    TX
    Good deal man! Thanks again!
  1. Painted my Fast intake
    By hijinx in forum Firebird / WS6
    Last Post: 02-25-2013, 12:36 AM
  2. Fast toys ram air/aftermarket lid/smooth bellow
    By Mudvayne24 in forum Parts Wanted / Trade
    Last Post: 08-22-2011, 02:31 PM
  3. Fast toys ram air/Air lid/Smooth bellow
    Last Post: 08-21-2011, 05:20 AM
  4. Painted Lettering - Fast 90
    By tatertot91 in forum Appearance Section
    Last Post: 11-30-2009, 02:07 PM
  5. Wanted: Slp smooth bellow intake
    By jdezao201 in forum Parts Wanted / Trade
    Last Post: 03-23-2009, 08:04 PM
