Results 1 to 13 of 13
    hanging around... LS1Jason's Avatar
    Mar 2009
    Henderson, Tx
    '99 -- Z/28 -- Pewter
    Headlight Restoration
    Though I'm looking at doing my motor mods before i worry about appearance, my headlights looked like crap. Was in ABC looking around and came across a kit to clean them up. Figured what the heck.
    http://ctown-crew.org/LS1/LS1-l.JPG
    Thats with the left side done. Before starting they both looked like the right side. No, its not 100% perfect. But, as you can see, compared to what the other side looks like, I was very pleased. Working right now, but if anyone wants the brand of the kit I'll look when I get back to the house.
    Dirty Harry hec33's Avatar
    Starkville, MS
    1999 Z28 M6
    I got the kit on friday and mine look so much better... I'm sure that the more work you put into it, the better they will look! My arm was shot after sanding! even used an electric buffer haha
    This is a lot better than buying new headlights IMO
    Mar 2009
    Henderson, Tx
    Yup. Granted, I'll eventually get new headlights, just didn't want to anytime soon. Actually went for a drive last nite after finishing, and man what an improvement on visibility.
    400rwhp::370rwtq Lucky 13's Avatar
    Little Elm, TX
    2002 T/A WS.6 -- ASC#12
    looks a ton better you just need to buff more, with a foam pad, and try plastX from meguiars (at an auto store) it will come out clear and you wont need the new headlights
    Mar 2009
    Henderson, Tx
    thanks. I'll pick up some meguiars tonight and try it out. that was the only thing that didn't go well with it. didn't polish up quite like i had expected. But, i was still thrilled with it over what they looked like before.
    All the kit consists of is 4 pieces of sandpaper (1000, 1500, 2000, and 2500 grit). Started with the 1000grit since they were so bad and went finer from there.
    Though, I can't actually say how much the kit costs. Looked back at the reciept last nite and realized the guy at ABC never actually rang it up. Depending on just how much it is, might be easier to just buy the pieces of sandpaper and then some polish. Since whats included was really only enough sandpaper for 1 headlight (keep in mind mine were horrible).
    Mar 2009
    Henderson, Tx
    well, picked up some a couple hours ago and came back home. I'll give the polish 2 thumbs up as well. Though after using it, i can definately tell which headlight i spent more time on. Really needed extra (new pieces) sandpaper for the second headlight. By the time I got through with the first, the sandpaper was shot. And it shows on the other light now that i used that polish.
    Thanks for recommending that Lucky13
    Auto Painter RyanJM's Avatar
    Houston, TX
    Want a cheap easy fix. I do headlights on the cars i paint for some local used car lots. Depending on how bad you can sand with 1000 grit and buff with 3m brown rubbing compound and a white foam pad. For those with trashed lights like my friends camaro I sand with anything from 400 to 600 grit depending on how bad I;ve even used 320 on a 3" random orbit sander. The tape up around your headlights and get a can of Duplicolor or and spray clearcoat you like and mist 1st coat, then 2 wet coats. Wet sand and buff them like a fender if you pick up dust, I use a spray gun and Dupont clear and i usually add a few drops of blk paint in the clear to give them a very lights smoke look. Looks good if done right and they work like new. if they go bad a few years later just sand and do it again.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    SS-EIAN SSNAKEATER23's Avatar
    CHICAGO
    SILVER
    1999 CAMARO SS
    Man what caused your headlights to do that? Do you have a bad seal around them?? I am all for cutting corners and not dropping alot of cash for new headlights cause they can be $$$$$$$$$. Good info though!!!
    Whisper Lid/SLP HarmonicBalancer/MAFTranslator/DiabloTuner A-Pillar Gauges (Aem Uego A/F,Trans Temp, D-Pic)Magnaflow CB w/CME Tips/ Eibach Pro Kit/ Brembo Cross Drilled/Slotted Rotors/ H.I.D.Kit
    Feb 2008
    york pa
    96 ws6
    Good info
    Mar 2009
    Henderson, Tx
    Quote Originally Posted by SSNAKEATER23 View Post
    not really sure what caused it. was like that when i bought the car a few weeks ago. eventually I'll buy some new ones, but this works for the time being.
    Aug 2000
    Indy
    sun/heat damage
    USA
    If you like. you can check this out. He restored his taillight and made it like new again.
    http://www.fullsizechevy.com/forums/...ghts-pics.html
    Hope it helps you to restore your headlight.
    ________________
    If you ain't first your last!
    Camshaft Bearing Set
    Apr 2009
    Oak lawn, il
    02 T/A WS6
    2000 grit and wax
  1. BG headlight restoration kit with pics
    By WICKEDLS1 in forum Showcar and Detailing
    Last Post: 02-24-2011, 10:34 AM
  2. Headlight restoration (pics)
    By GoFast908Z in forum Showcar and Detailing
    Last Post: 04-05-2010, 06:00 PM
  3. headlight restoration
    By mammoth713 in forum Camaro / SS
    Last Post: 08-17-2009, 04:29 PM
  4. Headlight Restoration Kit
    By LETHALxLS1 in forum Showcar and Detailing
    Last Post: 08-17-2007, 09:15 PM
  5. Headlight restoration?
    By SailorZ28 in forum Appearance Section
    Last Post: 03-28-2006, 07:41 PM
