Results 21 to 40 of 175
Thread: Cleaning Engine Bay
02-12-2006, 07:13 AM #21
Hey so what do ya'll use to clean the dash with if amorall is bad? ? i used WD-40 for the engine bay and it also leaves it nice and shinny like the day i bought her and it leaves the block shiny and i also live in texas so i know how SShaRK feels
02-14-2006, 01:29 PM #22
A couple of people just sayed to hose the thing... but wont that kill the opti and make things prone to short/rust??
02-15-2006, 03:47 PM #2396camaroSSGuest
Absolutely, if you've got an LT1 car. The guys saying to hose it down all have LS1 cars from what I see. They don't have to worry about a wet opti.
02-15-2006, 09:54 PM #24
50/50 water and simple green, engine brite cleaner and hose. CD2 as a detailer
02-16-2006, 09:45 AM #25
whats so bad about Armor all?
02-17-2006, 06:38 AM #26
- Jan 2006
- nc
Armor all will actually dry out your parts. Over time your dash (or whaterver) will dry up and start cracking. Very bad for the car.
02-17-2006, 11:31 AM #27
- Jan 2006
- WI
Black- 98 Camaro SS
Originally Posted by sketterman
02-17-2006, 11:51 AM #28
- Jan 2006
- nc
Quick question. Do you perform the cleaning and spraying with the hose while the eninge is off or on? I am assuming it is with the enigine off - having it on would generate heat which would quickly dissolve the cleaning agent/water.
But, I'm not sure so I thought I would ask.
02-28-2006, 07:54 AM #29
- Nov 2005
- San Diego, California
Pewter- 2000 Camaro SS
I recently bought Black Magic Engine cleaner. I was totally satisfied with it. Just follow the instructions on the can and then stand back and admire that new engine look. I picked it up at my local Autozone.
02-28-2006, 08:35 AM #30BBATCARGuestOriginally Posted by boone94
If you have an LS1 be careful spraying water towards the back of the engine . It will corrode the Knock Sensor under the intake manifold (I know by experience), costs $300 at the dealer to fix because you have to remove the intake. There is a GM service notice to build a "silicone wall" around the sensor, sensor is cheap, labor is Know problem with washing LS1 engine bays...
02-28-2006, 01:06 PM #31
- Feb 2006
- North Carolina
Taupe/Red- 2001 Trans Am Conv
Armorall rumors
You wonder where this stuff starts. Armorall is fine for your dash. I used it 9 years on my Formula (in Florida too!) and it was as perfect as Day 1. They are right about the engine and exterior. It doesn't harm anything but does attract dirt.
02-28-2006, 03:37 PM #32Originally Posted by Wayah-bird
03-11-2006, 05:40 PM #33
clean engine!!!!
guy's use SCRUBBING BUBBLES. buy it any where .it's for cleaning bathrooms just spray it on (it's foamy ) use i sm paint brush to phiscally clean the engine no scrubing then rinse off with water. NO PRESSURE just rinse . try it you'll like it
03-12-2006, 08:03 PM #34
- VA
Just for the benefit of everyone.Keep in mind that simple green is a corrosive.
It will corrode metal.So if you get it on wiring or elsewhere and it sits there it will corrode that area.
03-14-2006, 07:53 AM #35
well you dont use simple green at full concentrate and avoid areas with wiring or areas where it may trap at ie: strut mount area in engine bay. use it lightly and use a brush to clean the bay then rinse off with little pressure and constantly move the water around so water doesn't trap anywhere also.
Brandon
http://www.keepbringingit.com
03-26-2006, 03:51 PM #36
- Mar 2006
- Lansing, MI USA
Pewter- '99 Z28
OK, two things:
1) Simple green reacts with and corrodes aluminum over time. LS1s are aluminum. You do the math.
2) Armor All is not bad for your vehicle. It USED TO be bad, back when it was a solvent/silicone based dressing product. Now it has been reformulated and is water based. It's perfectly safe.
03-29-2006, 09:59 AM #37NecctionGuest
Ok soooo since you guys are saying Simple Green is corrosive and bad, but all the other guys recomended its use, whats the final count?
Should we or should we not use SG , and if not then what should we use instead. Now that spring is around i really gotta clean out that engine bay and i dont wanna screw up my baby by corroding something.
Thanks
03-29-2006, 12:27 PM #38
- Mar 2006
- Lansing, MI USA
Pewter- '99 Z28
Originally Posted by Necction
03-31-2006, 06:19 AM #39
SG's the best to me. that in conjunction with some CDL? engine spray.. i forget the name Csomething... anyways... can't mess anything in your engine bay with simple green if you spray it on.... use a mild brush for the very dirty areas... then rinse off using a low pressure setting and keep the water moving around the bay so water wont build up in any one spot. nuff said =)~
03-31-2006, 07:12 AM #40
- Mar 2006
- Lansing, MI USA
Pewter- '99 Z28
Originally Posted by EVL LS1
Read the thread. And... this link: https://safety.army.mil/warrior_stor...nid=2004930-42
If the DoD says it corrodes Aluminum, and I've seen it happen personally, I think I believe it.Last edited by 99Z28 1LE; 03-31-2006 at 07:42 AM.
Question Regarding Cleaning Engine/Engine Bay
By Badass WS6 in forum Showcar and DetailingReplies: 7Last Post: 08-07-2010, 04:44 PM -
By Badass WS6 in forum Appearance SectionReplies: 4Last Post: 07-20-2010, 06:22 PM -
LT1 Engine Cleaning
By MeatL0af in forum Showcar and DetailingReplies: 5Last Post: 06-18-2007, 01:39 PM -
How To Clean Your LS1 Firebird Engine Bay - Late Model Engine Bay Cleaning
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 06-01-2007, 10:00 AM -
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-24-2007, 01:20 AM
