Results 1 to 11 of 11
    Junior Member 96t/a's Avatar
    texas
    1996 Trans Am
    EGR & AIR delete
    how difficult is it to delete the air system, the egr system seems fairly simple.thanks for the help
    Aug 2006
    Missouri
    94 Camaro Z28
    I don't know, but it doesn't seem too difficult. I had to take the AIR pump off and that wasn't hard to get to. After that, I think all you need to do is plug up all the AIR connections, such as the 2 connections to the top of the exhaust manifolds.
    Member FUELS94's Avatar
    Cheney Wa.
    It's not hard at all to remove just like BlackLT1Z28. For 93-94 models you will not have SES light, but for 95 and up you will. There is a way to bypass the light just do a search on it.
    1996 Z28 LT-1 (with basic bolt-on)
    Oct 2001
    Colorado
    95 Z28
    You wont gain anything by removing either system, it just unclutters things (barely) in a forever cluttered engine bay.
    Detroit
    It not difficult at all to delete both the AIR and EGR.
    You can simply just remove the air pump and its tubes. Block the ports on the exhaust or get some headers.
    For the EGR, just buy an EGR block kit off of it e-bay.
    I would recommend getting both disabled in the computer.
    Jay
    Oct 2001
    Colorado
    95 Z28
    Quote Originally Posted by jagevileye21 View Post
    Jay
    If you dont, it will set a code(s).
    Aug 2006
    Missouri
    94 Camaro Z28
    Just fair warning... if you don't get race-style hearders, the EGR port connecting to the rear of the exhaust manifold is a PITA to get to and block off.
    Buffalo
    Quote Originally Posted by 5.0THIS View Post
    i agree. infact prolly will make yur gas mileage worse and could cause a gasy smell at warmup
    Member Orange99z28's Avatar
    joliet il
    orange
    99 z28
    ya know, i've been trying like hell to figure out why my car smells funky at wot and startup...i think this might be why... any possibility?
    i got an engine installed and they used real crappy air tubing that melted causing a horrible sounding car, i just capped the tubes with a plate on the copper lookin pipes comin off the headers. it's tuned with a predator so no check engine light, i also turned off the egr trouble codes.
    i'm really curious if this is related any info you have please share
    my oil cap is also not on tight, i'm wondering if that could be my smell? and can that cause low oil pressure?
    sorry for so many q's, thanks a ton though
    joliet il
    orange
    99 z28
    http://www.ls1tech.com/forums/showthread.php?t=500407
    good information on air and egr systems
    oops, i just reallized i'm in the lt1 section sorry, i used search, probably still some info there for ya, at least explains what they do...
    joliet il
    orange
    99 z28
    http://www.ls1tech.com/forums/showthread.php?t=673299
    another write up with pics for 98-99 camaros air system removal, sorry again, i'm putting it in mostly so people can search for it
  1. Question: MAF Delete??????
    By 98SSLS1OWNER in forum Computer & Tuning
    Last Post: 12-06-2010, 03:03 PM
  2. MAF delete?
    By tomz28 in forum General Help
    Last Post: 06-30-2009, 02:36 PM
  3. Delete This
    By ss~zoso~ss in forum Political / Debate Forum
    Last Post: 02-06-2008, 12:53 PM
