02-27-2008, 06:02 PM #1
Technical info write-ups and stickies
Here's a list of links to a bunch technical write-ups. If you don't see what you need here, check the other sections (ie the GTO or Drivetrain sections) that might pertain to what you want to do. Each section has some specific stickies that might help you out.
http://www.ls1.com/forums/f6/foot-well-lighting-185882/
http://www.ls1.com/forums/f6/how-bri...id-led-185822/
http://www.ls1.com/forums/f7/engine-...3/#post2893742
Routine Maintenance / Service Intervals
vats bypass
power window motor
broken seat belt guide
dimmer switch mod
door panels
steering wheel radio control lights
How to unlock your radio
http://www.ls1.com/forums/f63/altern...on-kit-178833/
How to program your key FOB
complete bolt on list
loose pcv valve fix
GM OBD diagnostic info
Lid plugs for a.i.r. system
gauges install
LC1 wideband install
Running wires through the firewall
OBD2 code list
troubleshooting the a.i.r. system ( see post number 5)
need help with one of these codes?
Secondary Air: Diagnosing and Removal
Step By Step - HID Light Upgrade
How to fix your F-body leaking heater hose pipes
Convert to LS6 valley cover
Broken alternator wire/connector repair
F-body long tube header install with pics
Carbon Fiber'd Interior trim pieces using Di-NOC
Battery hold down bolt replacement
Power steering pump removal, installation, and leak repair
How to keep the airlid clips down
steering column thread
Wobbly window fix
How to check for a bad starter
How to replace your Hazard and Turn Signal Flashers
The differences between OEM PCV vs LS6 valley cover mod
Installing a fixed belt tensioner
DIY LS1 cooling system flush(coolant flush)
Removing a seized or cross threaded lug nut
Longer is better!! Replacing wheel studs
Removing and replacing the stock power steering cooler
Installing Subframe Connectors
Line Lock Installation Instructions
K member swap
Camshaft swap how to
http://www.ls1.com/forums/f7/how-measuring-correct-push-rod-length-172530/#post2876821
http://www.ls1.com/forums/f63/header-install-117548/
http://www.ls1.com/forums/f8/my-8-8-rear-build-165553/Last edited by SMWS6TA; 07-26-2016 at 09:14 AM.
09-14-2011, 06:20 PM #2
- Apr 2008
- Madison, WI
Bump. There's been a lot of great write ups added over the past few months. Take a look at the list.
01-05-2014, 06:31 PM #3
Bump added Push Rod sticky
03-17-2014, 08:41 AM #4
Bump added the Alternator Relocation Thread.
05-29-2014, 07:18 AM #5
Added the 8.8 Rear & engine build threads
WANTED: more technical sticky write-ups
By Cutlass in forum Manual TransmissionReplies: 55Last Post: 01-11-2013, 05:23 PM -
General info write-ups and stickies
By 0rion in forum General HelpReplies: 0Last Post: 02-27-2008, 06:14 PM -
Thanks for the help and the stickies:)
By A 2000 SS in Jersey in forum Suspension and HandlingReplies: 0Last Post: 11-21-2007, 11:01 AM -
I need technical info!!! LS1-LS2
By dvdslw in forum General HelpReplies: 2Last Post: 08-19-2007, 11:36 AM
