Thread: Battery dead/stereo noise
03-14-2009, 09:48 AM #1
My battery is dead today but I can hear a humming noise coming from the Monsoon stereo when the car is off. But when I turn the key over the noise stops.
03-14-2009, 10:37 AM #2
sounds like a short some where pull the fuse(s) for the stereo, charge the battery and see what happens.
03-15-2009, 04:51 AM #3
- Oct 2005
- San Antonio
Silver & Black- 99 Camaro SS
Do you mean when you turn the key over "to start" the noise stops?
03-15-2009, 05:32 AM #4
Discharged batteries can do weird things... whatever is causing the noise from the stereo probably stops when you switch the ignition on as other electrical accessories try to draw power. The voltage drain is then too much for what it left in the battery and the noise stops. Charge it and then see what happens.
03-15-2009, 05:36 AM #5
- Nov 2006
- Indianapolis
^^^what he said. Dead or nearly dead batteries do funky things to electronics.
Or put a new battery in it, make sure the alternator is working, then you should be golden.
03-16-2009, 12:54 PM #6
Had the battery tested and was told it was perfectly fine. They guy said that not having a good ground sometimes makes the stereo hum. That's what it was. Good to know.
03-16-2009, 01:45 PM #7
- Nov 2006
- Indianapolis
So was the bad connection at the battery? That would make sense, or did you find a bad ground somewhere else?
Stereo display is dead?
By mraya in forum Stereo and ElectronicsReplies: 10Last Post: 08-22-2012, 08:06 PM -
Help: Dead Battery
By 35th-ANV-SS in forum General HelpReplies: 30Last Post: 03-29-2011, 06:53 PM -
Dead Battery
By j nix in forum Stereo and ElectronicsReplies: 6Last Post: 01-15-2011, 08:02 AM -
Question: dead battery
By slimss in forum General HelpReplies: 7Last Post: 09-11-2010, 01:54 PM -
Car Stereo is on LOC because battery died
By drock608 in forum General HelpReplies: 5Last Post: 04-11-2006, 11:12 PM
