Results 1 to 14 of 14
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    Stock LS1 Valve Springs...
    Now i have some ticking it sounds like a sewing machine under the hood... now i took off the valve cover and i could move my ls1 springs... is that normal... shouldn't they be inplace and be hard to move? i took 3 pushrods and they were fine... please help... it doesn't sound right... and it doesn't sound like a rod knock..
    Puyallup
    bump
    Could you go into a little more detail on what you mean by move them?
    I will try to get back to you tomorrow. Crashing.
    Puyallup
    I opened the valve cover... then took my fingers and wiggled the valvespings back and for a little... but it wasn't hard 2
    Puyallup
    bump night crew
    15 sec. Oh yeah, its fast UTVols98's Avatar
    Forest Lake, MN
    maroon
    2000 Z28
    Did you tighten the rockers down? I'm guessing that the ticking sound is the pushrod.
    RI
    Mag Red
    2002 Vette
    What is setup, stock? Any chance of a recent over-rev? The springs will move a bit if not compressed.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes, you can move the springs arouns with your fingers, when valve is in closed position.
    Puyallup
    nothing wrong... just tighten the rockets down to specs and it is back to normal thanks guys!
    Puyallup
    I tighten down the rockers and now they are fine thanks guys!
    caraholic ggino85's Avatar
    most miserable city in the US
    blue green chameleon
    hey redss, so are you saying you just tightened the rockers back to spec. and the ticking went away??
    sorry saw post #10, must have been typing at the same time you were posting.
    Forest Lake, MN
    maroon
    2000 Z28
    no problem.
    Junior Member glhs377's Avatar
    PGH
    LS6s14, 04Sti, GLHS377
    when they back out again, clean em up and use some loctite blue. red is too much.
  1. Are the stock Ls1 valve springs weak?
    By importssuck in forum Internal Engine
    Last Post: 05-03-2012, 05:14 PM
  2. New valve springs w/stock cam question
    By rel3rd in forum Internal Engine
    Last Post: 08-15-2007, 12:56 PM
  3. STock Valve Springs
    By redss454 in forum Internal Engine
    Last Post: 03-27-2007, 03:45 PM
  4. IL: stock 2002 LS1 cam and valve springs
    By shaitiger in forum Parts For Sale / Trade
    Last Post: 08-15-2006, 07:39 AM
  5. Stock valve springs?
    By rnl35thss in forum Internal Engine
    Last Post: 02-15-2006, 06:15 PM
