    024mula 024mula's Avatar
    Dec 2010
    Ohio
    '02 Firebird Formula
    Protect your rubber
    I had a few Firebirds in my life but this is the first one I have that has t-tops and I noticed it has a lot of rubber seals, around the hatch and up at the t-tops and down the door and if thats not enought Pontiac put rubber seal around the engine so when the hoods down its sealed.
    My question is what kind of protection does every body use on the rubber so it don't dry out, this is really nessary at the t-tops so they don't leak.
    Junior Member Louie23's Avatar
    Nov 2020
    Hercules, Ca
    I use a trim detailer by Meguiars. For plastics and rubber. It is not greasy you just have to work it through.
    Dec 2017
    Hinesville, GA
    So what protection did you use? My buddy is acquiring this Firebird from his uncle and the rubber seals need some attention. We'll work on it after we finished installing the suspension from 4Wheelonline onto the current Wrangler project. The Firebird has been sitting for about 3 years, hope the rust isn't too bad.
    Jan 2021
    California
    Which product did you end up getting?
    Feb 2020
    Los Angeles
    i too have used meguiars once upon a time after a recommendation from a friend.
    Dec 2010
    Ohio
    Quote Originally Posted by Austin Hale View Post
    I was asking what every body uses but right now I use spray silicone, spray it on a rag and then wipe it on the rubber.
    2002 Firebird Formula - 5.7 Liter - "Last of the Breed"
    Feb 2021
    USA
    A friend also advises you to use silicone spray, I wanted to ask you as an experienced person.Does it harm the lacquered surface of the car body or not?
    Dec 2010
    Ohio
    Quote Originally Posted by RXceptorr View Post
    That's why you spray it on a rag and then wipe it on the rubber.
  1. Customize and Protect With Armor All Custom Shield Coating
    By Ed Blown Vert in forum Showcar and Detailing
    Last Post: 12-05-2013, 02:56 PM
  2. Mother shoots/kills home invader to protect baby
    By BdAsBrd01 in forum Almost Anything Goes
    Last Post: 01-19-2012, 04:58 AM
  3. ITT: I show you how to protect yourself on the net
    Last Post: 07-26-2010, 09:45 AM
  4. divorce advice! How to protect myself financially!
    By RATCHETMASTER in forum Almost Anything Goes
    Last Post: 11-13-2008, 08:38 AM
  5. if you could only protect one which would it be?
    Last Post: 11-02-2008, 08:33 PM
