Results 1 to 20 of 75
12-18-2007, 03:25 PM #1
- Sep 2006
- mississippi
red white- 1999 z28 vert 1998 z28 ht
Fastest Convertibles Whats Your Times?
Just curious as I am trying to build my convertible now. What kinda track times or dyno numbers are you putting up. And lastly, what your combos. Help a brother out!
12-19-2007, 04:09 AM #2
I can tell you what I have experimented with if you think it will help.
My 02 SS convertable with an automatic weighs in at 3820 lbs. with me in it. Most of my runs were made at a DA of 2800 ft or higher,,,worst being 3400 ft. (typical Cincinnati crappy weather)
Bone stock ran 13.70's at 101 mph.
After my own tuning with HPtuner it went 13.40's at 104 mph with 4 13.44's in a row.
I recently installed long tube headers and off road Y-pipe,,,no additional tuning yet,,,made 2 more runs and had a little knock retard (2* on the shift points) and ran a best of 13.31 at 105 mph.
So the headers picked me up an honest tenth and one mph,,,
I have done all the free mods,,,,cutting under the air box, ported the throttle body, throttle body bypass, etc....but have seen no real results from this. Also installed underdrive pulley,,,but have seen no gains there either.
All runs made on street tires cutting consistent 2.11 to 2.15 60 foot times with mild wheel spin.
Not bad considering still a relatively stockish car thats no feather weight,,,,if I could just get a better DA reading closer to sea level I might tickle the 12 second zone.
Torque converter is next on the agenda,,,and for an auto it's probably the biggest bang for the buck. Should put me in the high 12's easily even with crappy DA,,,,then camshaft,,,then,,,,,,,,it never stops
12-22-2007, 08:41 AM #3
- Jun 2002
- Montreal, CANADA
depends which track... you want to know Mosport, Mt-Tremblant, Shannonville, St-Eustache ?
Eugenio_SS
12-22-2007, 08:43 AM #4
- Jun 2002
- Montreal, CANADA
btw, i have a LS2 stroker w/ plenty of tq/hp.
Sacrificed hp for more tq, since I roadrace more than drag... N/A, I have 508-511 rwhp between 4400-6600rpm
It's quite fun beast to drive
12-22-2007, 04:24 PM #5
12-23-2007, 10:49 PM #6
- Jun 2002
- Montreal, CANADA
well... first off, the car weighs 4300lbs.
i have 315s as skinnies, and the best i was able to run was 12.2 sec @ 122 mph w/ a 2.4 best 60' time.
can't use 1st and most of 2nd... lol so spinning through the half track.
from my understanding, i can easily get in the 10s with just traction... and my mph should increase as well when i can put some power down better...
that was on dead r-compounds. i rarely go drag-racing... i tend to road-race instead... prefer the twisties.
fwiw, it's a M6.
12-25-2007, 07:35 AM #7
12-25-2007, 08:28 PM #8
- Jun 2002
- Montreal, CANADA
My engine builder thinks i can get close to 130, provided i get some grip... and if i go under 4000lbs and get rid of 55+lbs on each wheel tire on all corners... I should be in lower 10s... but then again, need to not screw up on shifting.. lol
I figured that If I get a 1.6sec 60'... that means i save 0.6sec on the 60ft alone.
That, combined w/ the usage of 1st + 2nd gear, means i should be able to get close to 1.5 sec gains... imho... guess we'll see.
It's only #s, after all.
When my car was stock, I had a hard time getting in the 13s... some days would get it... but mainly very low 14s... maybe i'm no good @ upshifting... I'm great @ heal + toe, though... lol
01-24-2008, 11:02 AM #9
- Sep 2006
- mississippi
Surely there are more than the 3 of us with convertibles that are trying to go fast. What are your et's, mph, weights, and engien combo's? I already have TCI convertor 3000 stall, BMR weld in SFC's, magnaflow catback, p&p tb, tb bypass, ram air mod, eibach 1.2 lowering springs, UMI strut brace, UMI adjustible track bar, & UMI LCA relocation brackets. I am in the process of long tube headers with no cats, ls6 intake, camshaft, valve springs, pushrods, (or either RHS heads), ls6 oil pump, plugs, & new wires. I am just trying to see where this will get me. I am also going to add a ZEX nos kit in the future.
01-24-2008, 01:07 PM #10
I'm guessing there aren't many convertables out there,,,or at least convertable owners that actually race their cars.
For an update,,,I have done some additional tuning the car, since I haven't touched it after the header install and trip to the track. I finally got around to welding in an extra 02 bung so I can use the wide band on it to attempt to dial in the PE mode (WOT) tuning,,,then it will be ready for another trip early this spring.
Also have a converter to install, but waiting for one more trip to the track and see what tuning gets me,,,then it's converter time.
Just this damn weather is holding me up, tracks don't open here until late February or early March if weather permits.
01-24-2008, 01:10 PM #11
Have you weighed the car yet?? I would assume being in Mississippi the elevation is low, which may help to your advantage at the strip if the air is good.
Hard to say where your car will run based on those 2 variables I mentioned,,,plus the fact that you have a ton of changes listed on the car,,,have you base lined it yet by chance while still stock???
01-24-2008, 01:47 PM #12
- Aug 1999
- Arizona
When I first got the car. It was Nitrous and a converter. Spinning off the line I did a
11.72 @ 121.74 1.83 60'
I never got to the 1/4 track with the new setup.
Best in the 1/8 (Which was a parking lot)
7.06 @ 99.78 1.68 60' Qualcomm 125 ShotBlack 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
01-25-2008, 04:42 AM #13
- Sep 2006
- mississippi
Ed, you never got a chance to run it with the stroker motor? When you get it back up and running, keep me posted on the times, looks like you got a really fast droptop there. I am shooting for 11's on motor, and then shoot a 175 shot to it. Got some fast cars around here, got to run high tens on the street to compete.
01-25-2008, 06:22 AM #14
- Aug 1999
- Arizona
Never ran the new engine in the 1/4 just in the 1/8.
Our 1/4 track closed down before I got a chance. My guess I am in the low 11's. Last time I dyno'd with the P1 was 666 rwhp
01-25-2008, 07:27 PM #15
Well Just got my stock Camaro Z28 Covertible this month, the fastest time I got on the 1/4 is 14.05 et. Here is the list of upgrades that I have done since that run.
Headers
ASP Pulley
3.73 Gears
Cam
Slp Intake
3" Cutouts
I should be done with it by next Friday, So I will post the results, hopefully a much improved Covertible Z!
01-26-2008, 04:56 AM #16
01-26-2008, 07:51 PM #17
I don't have any 1/4 mile times but my 1/8 mile time is good i gues for whats done. 8.503 @ 83.2x mph with a 1.93 60ft and its an A4
I have free mods ss hood and intake, exhaust, sfc,lca, slp maf, and nitto 555 more to come
02-24-2008, 08:33 PM #18
mods and numbers in sig, 11.39 best run
Black 00 SS M6, vert, #0540 408ci
DD 2014 Sierra All Terrain
02-29-2008, 06:39 AM #19
i havent ran mine yet, hoping to get a tune and drag it this summer, but my mods are very basic, alright suspension setup, and a few performance mods, my car weighs 3800 lbs with a full tank and me in it, so its heavy
03-06-2008, 05:59 PM #20
I know im just making excuses ive had my vert for about a year now b/w maintainig it and paying for insurance I only work pt. time my mods list hasnt improved since i bought the car and i havnt made it to the track but what do you think it will run? heres what i got:
lowered 2 inches
KYB adjustables
metco LCA's
some kind of aftermarket pahard bar
free mods
lid
granatelli MAF
flowmaster
hypertech programer
it may have a clutch too- the trans has been out of the car and been painted orange
oh and a hurst shifter
Whats the fastest naturally aspirated 5.3 pass?
By hotrod7575 in forum Drag RacingReplies: 0Last Post: 06-23-2010, 01:00 PM -
Fastest Stock Track Times?
By VenomZ in forum Drag RacingReplies: 56Last Post: 11-09-2008, 07:57 PM -
whats the fastest u ever went in a race or alone
By Speedy_Gonzales in forum Kill StoriesReplies: 315Last Post: 10-16-2007, 03:10 PM -
Whats the fastest you've been clocked at?
By 02ultraZ in forum Almost Anything GoesReplies: 52Last Post: 08-02-2007, 10:46 AM -
Whats the fastest GM highway monster out their?
By EVO8 driver in forum Almost Anything GoesReplies: 43Last Post: 05-21-2006, 04:18 PM
