Results 1 to 1 of 1
Thread: Stalling issues
03-07-2024, 12:50 PM #1
- Mar 2024
- Virginia
Navy Blue Metallic- 2001 Firebird Trans Am
Stalling issues
Hey all. Not sure where to begin on this. I have a 2001 T/A that is an automatic. It has had the cam, intake manifold, and TB all upgraded. In addition, it has a Volant CAI in it. The tune was done by a reputable shop called P-Tuning.
The problem is when I take my foot out of the gas right before the 1-2 shift and it shifts into second, or right after it shifts into second, it will stall, but only when the A/C or defroster is on. If I have the HVAC totally off, it doesn't happen. I've replaced the IAC and it seems to be a bit better, but it still stumbles pretty badly.
To add to this, a couple days ago I got on it, and it downshifted hard, the tires scratched and then it acted like it shifted to 4th. I had to let off, then push the gas again to get it to downshift. It was almost like the torque converter locked up, but it is a pretty big RPM drop, more than what should happen from a stock converter locking up.
P-Tuning adjusted the TB a bit, and that helped, but they also raised the rolling idle, which also helped. Both of those were done before the IAC. The rolling idle was really high, and I was getting 11 MPG just driving around normally. I had them drop that down to just a little above normal. I'm not sure where to go from here, if this is something failing in the engine, or if this is a possible torque converter/trans issue.
As stated this has an automatic, but it has no traction control. Thanks for any help you guys can give!
my car is stalling
By jAgZ28 in forum LT1Replies: 6Last Post: 03-12-2011, 06:55 PM -
Car Stalling??????????
By ptownboy420 in forum General HelpReplies: 12Last Post: 07-17-2010, 08:06 AM -
Help: car stalling
By 99yellowz28 in forum General HelpReplies: 9Last Post: 04-25-2010, 01:04 PM -
Stalling
By lsx camaro in forum Internal EngineReplies: 11Last Post: 07-10-2009, 01:19 PM -
Z stalling out
By 94redmaro in forum General HelpReplies: 2Last Post: 05-30-2007, 02:58 PM
