Results 1 to 2 of 2
Thread: 2000 silverado 5.3 cam swap
05-14-2024, 05:04 PM #1
- May 2024
- Colorado
Goldish- 2000 silverado
I have a BTR Truck Norris cam kit for my truck and I'm ready to pull the motor and drill the broken manifold bolts etc.. But someone just told me about Ls6 heads on an ls1. I'm wondering if that's possible to do with the cam kit that I have because it came with lifters rods springs etc.
05-14-2024, 09:10 PM #2
Yes you can swap over 243 heads. BUT...... you need to measure for push rod length. Especially if you take heads to a machine shop and have them true up the surface. Highly recommend this if you get a used set. It's not hard to do. There's even a how to help thread in the Tech sticky threads.
6.0L Block - Forged 403ci, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Belstein Shocks, Hotchkis Springs (1" Drop), YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.73 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
00 FB Vert - Stock
Help: 1994 Silverado swap help please
By moodyholler in forum GM TrucksReplies: 0Last Post: 01-24-2022, 10:57 AM -
My Silverado, engine swap coming soon
By 04SilveradoMykk in forum GM TrucksReplies: 37Last Post: 01-30-2014, 10:17 PM -
Question: LS1 Swap 2000 Model Silverado 4L60E...will the trans hold up
By 00Silvy in forum Automatic TransmissionReplies: 0Last Post: 01-14-2013, 09:56 AM -
Selling my 2000 Silverado
By Danger731 in forum Western MembersReplies: 0Last Post: 05-09-2009, 04:06 PM
