Results 1 to 3 of 3
Thread: Running very rich
09-10-2009, 05:14 AM #1
- Jun 2008
- Houston
Artic White- 1998 Trans Am
Running very rich
Ok I just had got my new motor installed and had a 224/228 - 277/281 ,
.534 / .537 112 lobe comp cam installed, ported heads with 2.02 / 1.57 valves, longtubes, 92mm fast intake, 2800 stall, pro magnum rollers 1.75, no cats, air, egr and I've put a couple heat cycles on the motor but its running really rich? I have no codes being displayed....I need to get this thing going but I believe I have a slight smell of gass in the oil.....would this be a tuning problem or if my pcv system was kinked could this expose my oil to gas?
09-10-2009, 06:38 AM #2
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
check the rpm "window" for the cam. if you have a choppy idle and no cats your probably gonna smell a little gas. a tune would probably help little, and you would pick up a little more power there.
try reving up to around 2.5k and see if the smell goes away.
09-10-2009, 10:52 AM #3
Post the base file that you are using to get started with.
If you are running a stock file, we're gonna say "DUH! of course it's rich" and it needs some tuning.
Question: Why am I running rich?
By clg82 in forum General HelpReplies: 35Last Post: 07-22-2008, 12:37 PM -
Running WAY Rich
By Krazy351w in forum General HelpReplies: 6Last Post: 06-05-2007, 09:28 AM -
Running rich... what to do?
By Red00WS6_DreamBird in forum General HelpReplies: 4Last Post: 11-05-2006, 05:50 PM -
im running rich
By PgaNick in forum General HelpReplies: 7Last Post: 08-02-2006, 08:16 PM -
running pig rich
By z28rktec in forum General HelpReplies: 8Last Post: 01-26-2006, 07:45 AM
