Results 1 to 14 of 14
Thread: first time at the track
03-11-2007, 12:56 PM #1
- Oct 2006
- NJ
Red- 01 z28
alright the other night was my first time with the car at the track. it's an 01 z28 6speed. Only ran twice but only put up a 15.3. Was very chilly only about high 30's and was having trouble with traction. Anyone have any pointers on launching, shifting? Car only has the slp lmII catback. Any info appreciated. Thanks.
03-11-2007, 01:43 PM #2
tell us how you launched
03-11-2007, 03:10 PM #3
- Mar 2006
- Michigan
red- 1994 Camaro Z28
drag strip driving
get the tires hot first....try different rpm for your launch.to find what y our tires will absorb ..depends on the strip and your tires.. feel for traction as you are spinning the tires....don't over rev....better to shift a little soon than too late....dont power shift at first if you are not used to it...quick lift throttle shifts will work fine
03-11-2007, 04:20 PM #4
- Oct 2006
- NJ
Red- 01 z28
i was launching around 2k. Then shifting around the 5-6k range. Too high? Also when shifting into third the tires were breaking loose. Temp? Thanks.
03-11-2007, 04:22 PM #5
- Mar 2006
- Michigan
no i think ur shift point is ok....i m not sure what you mean by temp ....
03-11-2007, 04:43 PM #6
- Oct 2006
- NJ
Red- 01 z28
outside tempeture was only about 38 or so. Meaning maybe I had cold tires?
03-11-2007, 05:11 PM #7
- Dec 2002
- n/w chicago
get a pair of nittos on the rear.
feather the car out of the whole.2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
03-11-2007, 05:23 PM #8
- Jan 2007
- STL,MO
track temp was probably lower than 38, your never going to get good traction at the temp
03-11-2007, 05:50 PM #9
What tire pressure were you running? Also some suspension mods will help too. Torque Arm, LCA's and yep Nitto's would help too.
03-11-2007, 06:48 PM #10
- Oct 2006
- NJ
Red- 01 z28
speaking of tires.. I want to get rid of the stock 16's for possibly c6 wheels. Do I need spacers or anything or can they fit right on? Looking for probably a 17" wheel with 275's.
03-12-2007, 01:45 PM #11
the 275's will help, especially with a good tire on em
03-12-2007, 02:29 PM #12
- Feb 2007
- FairField, CA
RED 35TH ANIVERSARY PKG- 2002 CAMARO SS 35th LE
I don't think you will need spacer's on those.. They should convert right over.. I have some Z06 rims the C5 type and I didn't need spacers.. So they should convert right over.. Call the people who you are gonna get the rims from they should be able to tell you.. Or another Rim company..
03-13-2007, 02:48 PM #13
- Oct 2006
- NJ
Red- 01 z28
just found my slips: 1st run was 15.3 @ 92
2nd run was 15.3 @ 99
03-16-2007, 08:39 AM #14
- Feb 2007
- vivian, la
black- 1999 Trans Am
i think you should try shifting at 4200 it works for me
went to the track for the first time :)
By reaper ws6 in forum Drag RacingReplies: 22Last Post: 03-07-2012, 09:21 AM -
Question: First time at the track with the z28
By Jermocaleb in forum Drag RacingReplies: 9Last Post: 12-15-2011, 04:48 PM -
MVP Track Time 2010 Track Schedule
By Feffman in forum Road Racing / AutoXReplies: 0Last Post: 12-09-2009, 09:45 AM -
First time at the Track
By supercopone in forum Drag RacingReplies: 3Last Post: 11-21-2009, 09:40 PM -
Track Time
By ur jlus in forum Drag RacingReplies: 4Last Post: 02-05-2006, 06:58 PM
