    Junior Member reils1's Avatar
    Aug 2006
    Aviston, IL
    2001 Trans AM
    Angry Damn Pilot Bearing
    I cant seem to get the pilot bearing to come out for anything. I have already tried the slap hammer, grease trick, the toilet paper trick, and i have even tried to create my own puller. I am out of ideas. Does anyone have any suggestions?
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    do you have the car on a lift?
    Aug 2006
    Aviston, IL
    2001 Trans AM
    No. I have it up on jack stands, why?
    99 SS
    just thinking becuase u are so low on the ground u cant get any leverage as if you were standing up when its on jack stands.
    Work..Eat..Sleep..Repeat nut6778's Avatar
    Bethalto, IL
    Sunset Orange Metallic
    2002 Z28
    I'm telling you man...
    2 cans of air turned upside down, and freeze the damn thing. Then use ur puller and slam that SOB out of there. Give it a try, we do it on stubborn bearings all the time at work!
    Nut
    Aug 2006
    Aviston, IL
    2001 Trans AM
    Ill give it a try
    Aug 2006
    Aviston, IL
    2001 Trans AM
    Talking Finally!
    I tried about everything, and it had to be the last thing that i tried that worked. I used a die grinder with a carbide bit in it. It ate right through the bearing. I was amazed. I pulled it out with my finger!
  1. Help: Pilot bearing removel?
    By kingls1 in forum Manual Transmission
    Last Post: 04-29-2013, 09:35 PM
  2. Throw-out bearing or Pilot Bearing going out? Need help.
    By werewolf in forum Manual Transmission
    Last Post: 04-11-2013, 05:19 PM
  3. hatefull pilot bearing in LS1
    By nath in forum Manual Transmission
    Last Post: 06-01-2012, 05:35 PM
  4. FS: LS7 Clutch, LS1 Pilot Bearing
    By GoldenFlame in forum Parts For Sale / Trade
    Last Post: 05-23-2012, 07:18 AM
  5. Does it take a genius to get out my pilot bearing?
    By getcha01 in forum Manual Transmission
    Last Post: 02-06-2009, 03:55 PM
