Thread: Side winder
12-24-2016, 04:54 AM #1
- Jan 2016
- LaPorteTx
Blue- 1999 formula
Side winder
I was wondering if anyone ever experienced there ride going sideways real hard under hard excelleration and being Almost forced into the next lane when hitting bumps in the road at higways speeds? The inner and outer tierods were replaced maybe 6 months ago
1999 formula mostly stock
12-24-2016, 04:59 AM #2
My ass end would come loose all the time before upgrading the suspension. After installing lower control arms, a panhard bar, and a torque arm (coupled with new Nitto 555r drag radials), it went away completely. Likely the lower control arms helped the most as they are responsible for the front to back movement of the rear end.
In the case of your vehicle hitting bumps and jolting left or right, that sounds like a loose pan hard bar. The bolt hole ovals out over time causing it to loosen. Might want to check that out, especially if it's still stock. That's going on 18 years old.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
12-24-2016, 05:05 AM #3
- Jan 2016
- LaPorteTx
Blue- 1999 formula
Thanks bud the bump steer seemed to worsen with the passenger front tire it went away when i changed tires then that one ate it got a used one and it came back again
12-24-2016, 06:58 AM #4
The stock suspension pieces on these cars are pretty flimsy. Any upgrades out back will help plant whatever your tires can put to the road.
12-28-2016, 03:32 PM #5
- Feb 2006
- Orange County, NY
I had certain tires that made it worse. If you have different brand tires on the car it can make a difference, especially left to right. Wider tires also tend to follow the ruts in the road. Also as others said worn suspension parts can cause it also. Check on all the bushings front and rear.
12-31-2016, 03:26 AM #6
This will probably be the year our car gets new sneakers. Still interested in the M/T Street Comps at this point.
Help: Rear end noise! side to side clunking sound..C-clips broken?
By DaytonaBlues in forum DrivetrainReplies: 12Last Post: 11-14-2012, 02:30 PM -
hole in tire on the side not side wall just side
By qwik219d9 in forum Wheels and TiresReplies: 22Last Post: 06-17-2011, 12:50 PM -
404CI LS2 Carburetor Engine Build - High Winder
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-29-2010, 09:10 PM -
Camaro 1" lower on drivers side than Pass side
By hix5000 in forum General HelpReplies: 10Last Post: 07-03-2009, 05:16 AM -
2004 GTO moving side to side at idle
By John Carlson in forum GTOReplies: 10Last Post: 09-09-2006, 12:11 PM
