Results 1 to 20 of 21
Thread: "newb question"
07-09-2012, 12:13 AM #1
- Sep 2011
- Gillette, Wyoming
White- 1998 Camaro Z28
"newb question"
so, i put long tube headers and OFY... and plugs and wires on my 98' Z28. now when i really get on it, it hit's the rev limiter REALLY hard between 2nd and 3rd... i removed all the 02 sensors and am just running straight off the Y pipe (becuase i live in wyoming and there are no exhaust laws)... what can i do to fix this? mail order tune? or what?
07-09-2012, 05:14 AM #2
- Jun 2011
- Branchville, NJ
Send you PCM to Steve Williams at Tune by Frost who is a sponsor. Fill out the data sheet and pay the 150.00 you should have your unit back in 4 to 5 days.
07-09-2012, 12:25 PM #3
The reason you're running like crap is because of several things.
1) Deleting all the O2's not good for a EFI motor. Your pcm needs at least the front two O2 senosrs in order to properly set the fuel trims andread what the oxygen levels are in the exhaust. You need to put these back in.
2) Like Keith posted - get a Frost tune, wakes the car up and he can tune out the rear O2's, adjust the fuel tables and delete the air pump/egr stuff so your SES light doesn't come on.
3) Dumping the exhaust after the ORY - if it's too close you're losing some torque but not HP. Most will dump the exhaust using a E-cut out so you don't have the drone and can control when and where you want it. Usually the e cut out is located just under the rear passenger seat. Nice open spot there.
4) Rev Limiter - What are the rpms at when you hit it? Around 6200-6500 (max) is where it should be set at. V8's do not have high rpm's like the 4 bangers do. Most 4 bangers are in the 8-10,000 rpm range for their max rev limiter. Now there are some V8's that can get higher in the rpm's but they are special cars that have special tunes and cams and such. <<Think NASCAR
07-10-2012, 02:01 PM #4
- Sep 2011
- Gillette, Wyoming
Thanks for the info... I damaged one of the front o2 sensors when i was removing them, can i use the rear ones in the front? when you say i need the front two, you mean one on each side right? the ones in the collectors on the headers?
07-10-2012, 02:16 PM #5
No you can not use the rears up front..
In a nut shell,,Your front 02's are resposible for telling the PCM what the engines air fuel mixture looks like so that the PCM can make adjustments accordingly.
Even in speed density you need @ least one front 02 sensor.
..and yes you have 2 front 02 sensors, (As your car is OBDII not speed density), in this case in your header collectors, one for each bank of cylinders in your engine.Last edited by Smittro; 07-10-2012 at 02:22 PM.
07-10-2012, 02:53 PM #6
07-10-2012, 08:12 PM #7
07-10-2012, 08:17 PM #8
This guy here is a good place to start for a great tune and he's inexpensive..
Then,, you will only need to fix your front 02's (and any other issues) rather than buy what can be pricey widebands.
TunedByFrost.com - Professional Tuning For Your LSx Powered Car or Truck
Steve has a good rep for exceptional work and he's fast..Last edited by Smittro; 07-10-2012 at 08:20 PM.
07-11-2012, 02:45 AM #9
- Nov 2006
- Indianapolis
All the above, and remember the stock valve train is not designed to exceed 6200 RPM. Bends push rods. Ask any manual trans guy who's put it in 3rd instead of 5th. Yours is an AT car I assume?
07-11-2012, 08:16 AM #10
Had that situation at the track last Fri. Had a great 60ft and launch, sweet shift into 2nd and then screwed up shifting to 3rd with a Pro 5.0 shifter. I didn't keep the clutch in long enough to finish the shift. Lost race because I didn't force it into 3rd while in the high rpm range. Rather lose race then blow engine, clutch, rear end, tranny, etc.....
07-11-2012, 02:38 PM #11
I may be duplicating what i wrote on another thread but Its to my understanding you have to send in your PCM for a Frost tune? I live in Calif, in a ''enhanced'' smog area! meaning we have bi-annual smog tests. With my handheld im able to re-load my factory tune for the emmisssion test then after re-load any enhanced tune i have stored. Im wondering how i`d be able to do this with a Frost tune ?
07-11-2012, 02:46 PM #12
07-11-2012, 03:53 PM #13
07-11-2012, 04:57 PM #14
Ya, we still have it somewhat good here in Steeler Nation, they started visuals a few years ago in rural areas which is bs.
Cities are real tight on it..
The vehicle has to "appear" to have all it's emissions componets in rural areas..
But there are loop holes, grand fathered in too, and if we stay under 5000 mi. per year we are emissions exempt.Last edited by Smittro; 07-11-2012 at 05:00 PM.
07-11-2012, 05:36 PM #15
- Sep 2011
- Gillette, Wyoming
I'm searcing for new O2 sensors and none of them seem to say if they are front or rear... i took the old O2 sensors out of the exhaust i took off the car and the front and rears look identical.
07-11-2012, 05:42 PM #16
Yup! We have stages the visual is one that basically is up to the tech.Alot of them just look and see my Lt`s and say goodbye! cant help you! Some look the other way and focus on the cats..thats mandatory we have to have cats with an E.O. # (executive order #),Then the ''functional" test and then the actual ''sniffer'' test now run on a dyno type machine to simulate road conditions first @ 25mph ( like anyone goes 25) then the 45 mph. Often times the slower 25 mph is the one that`ll get ya! We have it rough here!! That is unless you have boat loads of money to spend and inatead of trying to get HP with mods you just get a high dollar muscle or exotic with 500 to 650 Hp stockl!
07-11-2012, 07:03 PM #17
Yeah Wa. ran the dyno tests back when I lived in Seattle. Would'nt give you your plate tags if you did'nt pass..
Stupid setup if ya ask me..
Back here in Pa. only OBD1 cars get the sniffer.
OBD2 get's a log reader. If your service engine light is on they won't even touch it.
We have state inspections and we can't get our inspection sticker for the windshield without first passing emissions then a safety check..
Another dumb setup imo. No loop holes in the city unless you know people and then it's a huge deal if they get caught.
So I keep something newer in the stable as a DD and the mileage down on the toys.Last edited by Smittro; 07-11-2012 at 07:06 PM.
07-12-2012, 02:42 AM #18
- Nov 2006
- Indianapolis
I like how they give you the loop hole about driving less than 5,000 miles per year. One could have several play cars that way, if you had $$$ for them.
07-12-2012, 03:23 AM #19
07-12-2012, 12:21 PM #20
Hussein Obama: Opponents to Iran "Deal" are "Crazies"...
By wileyCoyote in forum Political / Debate ForumReplies: 4Last Post: 08-26-2015, 11:11 AM -
Obama "Admits" to "Long Term Campaign" Against ISIS...
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 07-06-2015, 04:01 PM -
Hard Left in Knots over "Wacist" Prism of "Cat Call" vid
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 10-31-2014, 04:07 PM -
Weather Channel Co-founder: "Climate Change" is "Not Valid"
By wileyCoyote in forum Political / Debate ForumReplies: 7Last Post: 10-24-2014, 05:44 AM -
What "Google" Thinks of "Climate Change Deniers"...
By wileyCoyote in forum Political / Debate ForumReplies: 5Last Post: 09-23-2014, 10:19 AM
